wastegate open at idle
Old Jun 10, 2007 | 08:57 AM
hyabusa hunter's Avatar
Default wastegate open at idle
hey guys, i have a 44mm tial on a fullrace manifold. i have a screamer pipe. there is exhaust gas coming out at idle, i took the wastegate off, the" piston " inside the tial, the diameter is smaller than the casting hole in the main body of the tial wastedgate, so gases are just floing past it,
or is it just me and they come like this?
Default Re: wastegate open at idle (hyabusa hunter)
just to add, even with the vacuum lines pulled of the wastegate, makes no difference
Old Jun 10, 2007 | 09:03 AM
twkdCD595's Avatar
you need the valve seat/ seal ring that goes in the bottom of the wastegate.
looks like this.
Old Jun 10, 2007 | 09:17 AM
ProJectCvic's Avatar
Default Re: wastegate open at idle (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">you need the valve seat/ seal ring that goes in the bottom of the wastegate.
looks like this.
Old Jun 10, 2007 | 09:28 AM
i dont think i got anything like that wen i bought it, just a v band flange which we made the screamer pipe from? mmmmmm very strange should that not have been fitted in there alreay?
Old Jun 10, 2007 | 09:42 AM
don't matter..vband has firing ring too.
Old Jun 10, 2007 | 09:47 AM
Default Re: wastegate open at idle (ProJectCvic)
no, i mean a have a v band flange to weld my screamer pipe.
Old Jun 10, 2007 | 09:50 AM
Fitti's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter &raquo;</TD></TR><TR><TD CLASS="quote">no, i mean a have a v band flange to weld my screamer pipe. </TD></TR></TABLE>
I think you weld the firing ring and made your dumptube. Either way it sounds like you need a firing ring.
Old Jun 10, 2007 | 10:04 AM
Default Re: wastegate open at idle (Fitti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti &raquo;</TD></TR><TR><TD CLASS="quote">
I think you weld the firing ring and made your dumptube. Either way it sounds like you need a firing ring. </TD></TR></TABLE>
i dont think so, cause if the firing ring was the same size as the v band flange, the thing would never mount up? true? it seems the firing ring fits inside the main body, sort gets pressed in right? i can see there is a slight recess on the main body
Old Jun 10, 2007 | 11:16 AM
RedEj8's Avatar
The fire ring goes inbetween your wastegate and your manifold/wasegate flange.Acts as a valve seat if im not mistaken. Theyre usually not pressed in but they just sit in there and can fall out easily when the wastegate is not installed.
blinddan
Mar 22, 2006 03:13 PM
godrifttoday
Nov 23, 2004 01:02 PM
egturbo
Jul 16, 2004 03:55 PM
r7
Jul 30, 2003 02:29 PM
88crxvtec
Jun 21, 2003 08:40 PM
