axel stuck
Old Jun 10, 2007 | 07:19 AM
tegdude227's Avatar
Default axel stuck
i ve searched all over but my pasenger side axel is stuck in the hub i need that thing out ive beat on it with a 2 pound hammer and it sosent even budge. its like its seized inside the hub any input wount be great ? thanx and its also on a 97 gsr
Old Jun 10, 2007 | 08:44 AM
Chiovnidca's Avatar
Default Re: axel stuck (tegdude227)
I use an air hammer with a blunt nose bit.
Old Jun 10, 2007 | 09:00 AM
ek_chris's Avatar
heat it up cherry hot and use an air hammer. Or if its really stubborn take the knuckle off and put it in the press
Old Jun 10, 2007 | 09:13 AM
dtapia's Avatar
Default Re: (ek_chris)
this is what i have used for years and works great for them stuburn axles that are rusted in the hub's. this is made my mac tools
Old Jun 12, 2007 | 12:00 PM
tegdude227's Avatar
Default Re: (dtapia)
i have a heat gun but will that get it hot enought ?
Old Jun 12, 2007 | 12:17 PM
Bailhatch's Avatar
Default Re: (tegdude227)
^nope.
just try an air hammer/chisle first. I have a a cheap one and it seems to get out ones that a hammer wont touch with ease. Sometime you have to just hammer away for a minute before it moves but it beats taking it apart and pressing it. I use a pointed tip though, so it sits right in the dimple.
also soak both back and front with some PB or WD or something
Old Jun 12, 2007 | 03:38 PM
tegdude227's Avatar
Default Re: (Bailhatch)
yea i sprayed PB on it then beat it but nothing ill try a air hammer tomorrow. then i have to get the ball joint out how much fun is that going to be ?
Old Jun 12, 2007 | 04:11 PM
hitekper4mance's Avatar
lmao. good luck trying.
Old Jun 12, 2007 | 05:33 PM
Bailhatch's Avatar
Default Re: (hitekper4mance)
the ball joint is ****. just back the nut off a few turns to protect the threads and beat the **** out of the bump on the side with your 2lb hammer. l lot of times it only takes 2-3 hard hit even on old ones.
Old Jun 13, 2007 | 03:30 AM
tegdude227's Avatar
well im replacing both the axel and the ball joint so i dosent matter to me if i destroy them
Old Jun 13, 2007 | 01:47 PM
Bailhatch's Avatar
hammer away then...dont forget the snap ring. and have fun getting it out of the spindle. they can be very tight, air hammer territory for sure.
civicdelsol33
Nov 28, 2008 08:04 PM
Pac-Man_G
Paint and Body
Sep 16, 2008 05:45 PM
PatrickGSR94
Jun 14, 2007 05:50 PM
pbcdb
Mar 13, 2004 03:38 PM
43MA
Jan 16, 2003 05:02 PM
