A few 88-89 cosmetic questions.
Old Jun 10, 2007 | 06:53 AM
Tuner Eddy's Avatar
Default A few 88-89 cosmetic questions.
Well, I need a new passenger side fender and front bumper for my 89 crx hf. I just had a few questions. Will the 90-91 front bumper work with the rest of the 88-89 front end, or do i need to replace the entire front end? And will the 88-89 radiator support need to be replaced with the 90-91?
Now to my interior, I have the terrible blue interior. I recently picked up a 90-91 black dash, and I need to know if it will fit without any problems, and which door panels am I gonna need?
I searched for this in the FAQ and a few searches and found nothing.
Thanks in Advance.
--Ryan
Old Jun 10, 2007 | 11:18 AM
143MYVTECEF's Avatar
Default Re: A few 88-89 cosmetic questions. (Shift_Vtec)
usually with most interior and exterior pieces its year specific.
88-89
and
90-91
Old Jun 10, 2007 | 11:34 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shift_Vtec &raquo;</TD></TR><TR><TD CLASS="quote">Will the 90-91 front bumper work with the rest of the 88-89 front end</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">do i need to replace the entire front end?</TD></TR></TABLE>
No. The only thing you'll need other than the bumper and bumper support are the bumper turn signals.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">And will the 88-89 radiator support need to be replaced with the 90-91?</TD></TR></TABLE>
They are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I recently picked up a 90-91 black dash, and I need to know if it will fit without any problems</TD></TR></TABLE>
The dashboards are the same. The difference is in the gauge cluster, the cluster hood & attached switches (rheostat, defroster, hazard), and the wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and which door panels am I gonna need?</TD></TR></TABLE>
The '89 HF has pillar-mounted seat belts, so you need door panels from another CRX or Civic hatchback with pillar-mounted seat belts. This includes:
- '88-89 Civic 3dr - all
- '88 CRX - all
- '89 CRX - HF only
JDM and Canadian door panels will also work. What will not work are panels from a car with door-mounted seat belts, which include:
- '89 CRX - DX & Si only
- '90-91 CRX - all
- '90-91 Civic 3dr - all
Old Jun 10, 2007 | 01:29 PM
HonDelso's Avatar
^^^ is correct.
HF front bumper supports are lighter than DX/Si.
88-89 are the same
90-91 are the same.
the don't interchange without missing a bolts in the bolting locations. but the bumper themselves are interchangeable.
edit:
the dashes are the same. only real difference is the wiring under it. you use your original car wiring. you will have a few buttons that don't work since you car might not have wiring for. (i.e. hazard button on the dash since 88-89 HF has it on the steering column.)
Old Jun 12, 2007 | 06:32 AM
Tuner Eddy's Avatar
thanks guys, only last question is.......the passenger finder, can i get any year crx fender (88-91) or does it need to be for an 88-89?
Old Jun 12, 2007 | 06:47 AM
meancivicsi's Avatar
Default Re: (Shift_Vtec)
the fenders will fit but you the difference is the corner lens. the 90-91 type corner lens does not utilise screws whereas the 88-89 type corner lens does.
Old Jun 12, 2007 | 06:59 AM
Tuner Eddy's Avatar
Default Re: (meancivicsi)
so if I run the 90-91 fenders, then I need 90-91 corners, and vice versa, correct?
Old Jun 12, 2007 | 07:10 AM
correct
Old Jun 12, 2007 | 07:24 AM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meancivicsi &raquo;</TD></TR><TR><TD CLASS="quote">the fenders will fit but you the difference is the corner lens. the 90-91 type corner lens does not utilise screws whereas the 88-89 type corner lens does.</TD></TR></TABLE>
90-91 still utilizes one screw
Old Jun 12, 2007 | 07:35 AM
Default Re: (JustAnotherRex)
true that, allow me to rephrase. 88-89 utilises EXTERNALLY VISABLE screws
Old Jun 12, 2007 | 02:06 PM
Targa250R's Avatar
be professional
This is true, however the difference is not in the fender itself. All '88-91 USDM CRX fenders are the same. The corner markers attach to two small $1.60 replaceable inserts at the front of the fender. It's not the not the year of the fender, but rather the type of insert (screw-in '88-89 or slide-in '90-91) that determines which corner markers you can use (or vice versa).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shift_Vtec &raquo;</TD></TR><TR><TD CLASS="quote">so if I run the 90-91 fenders, then I need 90-91 corners, and vice versa, correct?</TD></TR></TABLE>
No. All you have to do is swap the inserts from your old fenders onto your new fenders - then you can reuse your old corner markers.
You can't run '90-91 corners without also having '90-91 headlight brackets anyway, because the tab that the '90-91 corner marker screws into on the headlight bracket is missing from '88-89 headlights.
Old Jun 14, 2007 | 05:05 AM
Tuner Eddy's Avatar
i tried to google image some 90-91 front bumpers, and it came up with some body kits.......you guys got any pics?
Old Jun 14, 2007 | 03:51 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shift_Vtec &raquo;</TD></TR><TR><TD CLASS="quote">i tried to google image some 90-91 front bumpers, and it came up with some body kits.......you guys got any pics?</TD></TR></TABLE>
Good lord There are a gajillion '90-91 CRXen posted in the picture sticky thread at the top of this forum.
Old Jun 19, 2007 | 04:13 PM
97SS's Avatar
Just some friendly advice, don't get scammed out of your hard earned money from this guy like I did.
He ripped me off selling me a $200 transmission that didn't fit my CRX after he 'guaranteed' me it was what I was looking for then backed out of reimbursting me part of the cost after we agreed to it!
See my clicky below for the full story...just beware of this shady guy
93_db2
Aug 7, 2007 07:53 PM
s0lefreshh
19
Apr 21, 2007 05:08 AM
phatride
14
Oct 17, 2004 06:14 AM
spoolin92
Dec 11, 2003 10:27 PM
MetalKill
Dec 7, 2003 05:41 PM
