Code 9 dohc zc
Recently swaped a dohc zc into my 90 crx si along with a new wiring harness pg7 ecu and IACV, Pretty easy swap overall did the dizzy/cps wireing and all right. I'm pretty sure my timings on it might be off by like 1 tooth, the car runs and drives perfect at all rpms/gears aside from idle. If it let it idle for like 20 seconds or so once the car warms up it will die unless i feather it http://home.comcast.net/~techn...l.swf said to check the OHM's on the cps my ohms where at 1090 wich isnt that far out of range has any 1 ever had or heard of this problem and knows of a fix for it or if replacing the CPS would solve this please respond back thank you
if you have code 9 on the DOHC ZC and the Cylinder sensor is wired correctly, 99 times out of 100 you have the camshaft timing off - exhaust cam is off by one or more teeth - the Cylinder sensor rarely goes bad
DJ_SaNdOz
11
May 28, 2003 08:34 PM
