225-50-15 on a 15X7 wheel??
Old Jun 9, 2007 | 10:54 PM
Fallen86's Avatar
Default 225-50-15 on a 15X7 wheel??
hey guysss, i'm out for the wide look and i dont like now 205-50-15s kinda bend in on a 15x7 wheel, does anyone have pics of their 15x7 with 225 tires??? and how is the handling? is it slushy? or is it stil crips? Thanks in advance.
Old Jun 9, 2007 | 11:16 PM
DaveSi677's Avatar
Default Re: 225-50-15 on a 15X7 wheel?? (Fallen86)
your handling is not going to be great with all the rubbing you are going to be having! If you are worried about handling why not get the right size tire for your car but with a stickier compound!
It is a true misconception wider is better because it really has to do with how sticky is the tire!
Old Jun 9, 2007 | 11:39 PM
Fallen86's Avatar
Default Re: 225-50-15 on a 15X7 wheel?? (DaveSi677)
actually i was thinkin the handling will be compromised cuz of the extra width... not rubbing... does it really rub that bad with 225? i have a 97 coupe
Old Jun 9, 2007 | 11:41 PM
EGPrelude's Avatar
^^ whats your offset? It might rub REAL bad.
Old Jun 10, 2007 | 06:44 AM
GReatEDDY's Avatar
on 96-00 Coupes I have found the 215-45-16 works perfect. Not a huge selection but I does offer the most tread on the ground without rubbing. The 225-50-15 works on track cars with the fender liners removed and the fender lips rolled. But also consider the weight difference. Check out some of the manufactures spec pages and look at the tire weights the 225-50-15 isnt light, and works best on 15x8.
Old Jun 10, 2007 | 10:56 AM
Fallen86's Avatar
Default Re: (GReatEDDY)
i'm not gonna drop my car like its hot though, most like i'll be running on eibach prokit springs
Old Jun 16, 2007 | 03:30 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Fallen86)
For 15" wheels on a '97 Civic Coupe, get 205/50-15 or 195/55-15. If you're looking to maximize performance, get the Falken Azenis RT-615 in 205-50-15. It fits fine on 15x7 wheels, and will give you better performance (on dry pavement) than any other 15" street tire, including ones in 225 treadwidth. (It's also notorious for being wider than other tires labeled 205/50-15, so it may give you the "look" you want, too.)
Old Jun 17, 2007 | 03:56 PM
Han Solo's Avatar
Default Re: (nsxtasy)
225/50's look like balloons on our cars try either a 205/50 or 225/45.
Old Jun 17, 2007 | 07:14 PM
Fallen86's Avatar
Default Re: (VTECommie)
alright, mb its too extreme. Thanks guyS!
Costco
Apr 9, 2011 10:26 PM
WeakSi
Jun 29, 2010 02:39 PM
Chris F
Mar 28, 2005 06:58 AM
Flux
Mar 5, 2002 07:19 PM
