D16Z6 VTEC Pressure Switch wire color
What are the colors of the VTEC Pressure Switch wires on the plug? 96 DX with Z6 head and ECU (Boomslang harness). I cut the clip off a 92-95 VTEC engine harness. It was the only green plug that would fit the Pressure Switch. Has blue/black and solid black wires.
I just need to know if its the right clip, and what color wire goes to the ECU. I have the solid black going to the ground on the thermostat and am throwing CEL 22. Yes, I've searched, a lot.
I think I have the wrong plug. Referring to Bauleys Mini-Me writeup, the plug he got from a junkyard clip (VTEC pressure plug) is yellow with a blue and a black wire.
No yellow plug on the Z6 engine harness.
Tried bypassing the swtich by running a wire from pin C15 (Pres Switch for OBD2) to the VTEC solenoid wire (splied it). CEL 22 didn't go away.
got a b18c5 (with no vtec pressure switch) fitted the solenoid with switch but no where to plug it i
ben_vtec
May 15, 2002 03:38 PM
