Edm corner light wiring?
Old Jun 9, 2007 | 08:18 PM
Casey's Avatar
Default Edm corner light wiring?
Well Expo is here and ill be picking up some edm corners from mark (blueR). From what hes told me, the wiring is a little different on them than usdm ones. Makes sense, seeing as they light up differently than usdm ones(pic below). Does anyone know how im going to have to wire them up? Any input would be greatly appreciated, thanks!
Old Jun 11, 2007 | 03:07 AM
unslanted's Avatar
Default Re: Edm corner light wiring? (Casey)
I used to have those...if you don't want to merc up your wires incase eventually you wanna switch back to stock, then simply cover the smaller constant filament on your blinker bulb with electrical tape...notice how there are two metal connections on the bottom of the bulb itself...one of them is the right one ,(the constant)...so if you pick the right one then the bulb will only light up for signals or hazards
Old Jun 12, 2007 | 03:31 PM
Casey's Avatar
Default Re: Edm corner light wiring? (unslanted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unslanted &raquo;</TD></TR><TR><TD CLASS="quote">I used to have those...if you don't want to merc up your wires incase eventually you wanna switch back to stock, then simply cover the smaller constant filament on your blinker bulb with electrical tape...notice how there are two metal connections on the bottom of the bulb itself...one of them is the right one ,(the constant)...so if you pick the right one then the bulb will only light up for signals or hazards</TD></TR></TABLE>
thank you sir
OddieBroddie
Mar 2, 2012 11:04 PM
For_Sale
Dec 1, 2005 05:43 AM
B18C-VTI_R
Jul 13, 2004 07:00 AM
RedHackBatch
Jul 6, 2004 09:39 PM
NUBREED
Apr 18, 2004 06:48 PM
