HELP Bizarre Spark Problem...
Old Jun 9, 2007 | 06:52 PM
murray195's Avatar
Default HELP Bizarre Spark Problem...
Ok, so I've been checking for spark and have come upon an interesting but disturbing issue. I don't see spark until I let go of the ignition... then it fires off one spark. And there's only really spark coming through on #1. The coil is good, the igniter is good, theres a new cap and rotor... I'm all out of ideas. Please help!
Old Jun 10, 2007 | 09:03 AM
erixxxhouse's Avatar
Check your plugs. The wires might be corroded or it might nnot have a good connection. Also make sure that the wires are going into the pulgs correctly. Pull on them slightly and then push them in. Make sure there is no play. If there is then pull it out and expand the clip a little bit and push it back into the plug.
GL.
Old Jun 10, 2007 | 09:04 AM
Default Re: (erixxxhouse)
oh... I dont mean spark plugs. I mean the plugs that connect to the distributer... its the one with the blue white and all the other colored wires on them.
Old Jun 10, 2007 | 12:57 PM
murray195's Avatar
just to be sure that it wasn't my wires, i touched a multimeter to the distributer plug-in for the wire while my buddy cranked it over. there was nothing until he let the key go and then it fired off one charge... so i guess it can't be plug wires unfortunately.
ty_uni_ek08
Oct 14, 2008 12:46 PM
909rex
May 17, 2007 03:14 PM
b16b18
Sep 6, 2006 12:56 PM
fassassin
Feb 7, 2005 05:02 PM
95turbohatch
24
Apr 7, 2004 08:07 PM
