running slow
Old Jun 9, 2007 | 06:49 PM
sick93sol's Avatar
Default running slow
I have a 93 del sol with a 170 hp B16A, but me and my friends can only get it to run as low as 16.2 in the 1/4 mile. I replaced my TPS and O2 Sensor. But sometimes when I start out in 1st gear it lags until about 4000 rpm, then it kicks and drives faster. And whil eim cruising at like 70 mph and i have my cruise control on it will kick randomly like its gotten more power. I dont know whats going on, so if anyone can help that would be awesome.
Old Jun 9, 2007 | 06:58 PM
cashshoes's Avatar
maby timing, dizzy, spark plugs, compression
one way to know if ur not getting any compression is if takes a long time to crank up for the first time if not that then prob timming
Old Jun 9, 2007 | 07:00 PM
sick93sol's Avatar
Default Re: (cashshoes)
how do i fix the timing
Old Jun 9, 2007 | 07:11 PM
dtapia's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cashshoes &raquo;</TD></TR><TR><TD CLASS="quote">maby timing, dizzy, spark plugs, compression
one way to know if ur not getting any compression is if takes a long time to crank up for the first time if not that then prob timming</TD></TR></TABLE>
ok im not real upto date on the lingo here but what the hell is dizzy ?
Old Jun 9, 2007 | 07:15 PM
ke98248's Avatar
Default Re: (dtapia)
distributor cap
Old Jun 10, 2007 | 09:17 AM
cashshoes's Avatar
what i like to do is take out number 1 spark plug put a long extision in the whole and turn the crank until the piston reaches TDC in your case sense your just checking do that and when piston is TDC look at ur cams make sure they are TDC if one is off then prob ur timming
keep it going
Dec 7, 2016 11:10 PM
HellaFab
13
Sep 21, 2011 04:10 PM
G2integra217
Apr 8, 2005 07:27 PM
scUba-stEve
18
Mar 25, 2005 10:20 AM
MisterHYBRID
Sep 30, 2003 10:24 AM
