knocking sound at deceleration
Old Jun 9, 2007 | 06:22 PM
JLefevers's Avatar
Default knocking sound at deceleration
ok when i come to a stop i hear this weird knocking sound coming from the left rear area. i checked all my lugnuts and all the suspension. i can figure it out. could it possibly be my tire not balanced or sumthing. it sounds kinda like a clunk clunk and as i slow donw more the sound slows down also. kinda hard to explain so i'm trying. anybody else experinced this???
Old Jun 9, 2007 | 06:27 PM
EF_LSVtec's Avatar
Default Re: knocking sound at deceleration (JLefevers)
Are you on your brakes when you're slowing down? Try engine braking and see if you still hear the clunking sound without stepping on the brakes.. It could be that your calipers are loose or maybe axle nut? Check your crossmember bolts too along with radius rods if they're tight.
Old Jun 9, 2007 | 07:39 PM
Turbomd's Avatar
i say rear caliper slide bolt is broken and banging into the wheel when you come to a stop.
Old Jun 10, 2007 | 12:11 PM
JLefevers's Avatar
Default Re: (Turbomd)
i have drum brakes on the back. i pulled the drums apart and everything looks good but yet i still hear the clunkin sound. anyone else??
Old Jun 11, 2007 | 02:29 PM
JLefevers's Avatar
Default Re: (JLefevers)
ttt
Old Jun 11, 2007 | 07:03 PM
JLefevers's Avatar
ttt this is driving me nuts i can not fiqure out what it is i have dont taken the whole wheels assembly apart checked my drum brakes checked my suspison but still it knocks when i slow down only when i am almost at a complete stop does it start to make the sound.
Old Jun 11, 2007 | 07:20 PM
sexyrex's Avatar
rotate tires and road test, while you're at it inspect brakes and anything else out of the ordinary. spin the wheel also....go from there first
tlsole
Dec 7, 2009 09:01 AM
924doorEG
Jun 7, 2008 03:07 AM
chevellion
Aug 11, 2007 08:34 AM
Ricey McRicerton
48
Jul 24, 2004 07:50 PM
