99 ex/ ls swap
i need some help with the parts i will need, can i use the stock ex harness or will i need a ls one, the ls motor is out of a 92/93 ls so it is obd1. what mounts will i need, what ecu is best for this swap? what clutch pedal do i use, because i am doing an auto manual swap aswell. thanks alot
Use the civic harness - it will all connect, except for the IAT.
Mounts: EM1 driver side engine block mount, EM1 rear engine bracket, front lower B series trans braket, P7J CRV AC bracket
Get a full manual pedal set from any 5sp civic 96-00 if you want a 100% guaranteed fit
All of this has been covered many, many, many times before
In the future please search...
thanks alot guys, i have searched but i just wanted to get a better list of what i needed because most people dont usually do the auto/ manual swap at the same time as the motor swap. just needed a better parts list of the stuff i needed
hd99white
May 6, 2008 07:08 PM
theslugbug
Jan 1, 2007 06:42 PM
