engine mounts
Old Jun 9, 2007 | 02:23 PM
ek9child's Avatar
Default engine mounts
wat engine mounts do i need to do a swap for a 98 civic HB. the swap consist of b16 tranny with a b18b1. is it possible to reuse any of the stock engine mounts?
Old Jun 9, 2007 | 02:32 PM
t0p_sh0tta's Avatar
Default Re: engine mounts (ek9child)
It can't be done unless you READ THE FAQ AT THE TOP.
Old Jun 9, 2007 | 03:03 PM
Mr_Si-R's Avatar
you are going to need b series mounts all the way around. cant reuse any of the old mounts
look here: http://www.hasport.com/
and here: http://www.innovativemounts.com/
but please search before you post something that may have been covered before
Old Jun 9, 2007 | 03:07 PM
vsmhatched's Avatar
you can use the stock driver and trans mount, need a 99-00 si rear mount and rear t-bracket
vsmhatched's Avatar
Default Re: (Mr_Si-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Si-R &raquo;</TD></TR><TR><TD CLASS="quote">you are going to need b series mounts all the way around. cant reuse any of the old mounts
but please search before you post something that may have been covered before </TD></TR></TABLE>
I re-used mine except the rear
Old Jun 11, 2007 | 07:05 AM
ek4_b16a's Avatar
Default Re: (GreyDel)
yes that is true...but it'd be best to swap out the driver side, cause them stock mounts won't be able to handle the torque from the ls...just get an aftermarket driver side mount for it and the SI L bracket for the rear...two main mounts for the swap...GOOD LUCK!!
Old Jun 11, 2007 | 07:12 AM
crazyguy's Avatar
Default Re: engine mounts (GreyDel)
the rear bracket u can use the dc integra or b16a del sol and use your old rear mount too
xwhitchx
15
Jun 19, 2009 08:30 PM
EG6Boy702
33
Apr 27, 2009 03:55 PM
Poroshok
Jul 16, 2007 07:12 PM
invisible
21
Dec 26, 2006 08:38 PM
b16hatche
Nov 7, 2005 03:43 PM
