Need 5 lug help for s2000 wheels.
Old Jun 4, 2002 | 02:42 PM
racecarpete's Avatar
Default Need 5 lug help for s2000 wheels.
wasup guys, i want to do a 5 lug and got a good offer on some s2000 wheels. Will they fit if i do a 5 lug conversion? thanks.
Old Jun 4, 2002 | 02:51 PM
YodaIsGod
Guest
Posts: n/a
Default Re: Need 5 lug help for s2000 wheels. (SilverCivic2k)
yes and no.
yes the should have the same lug pattern. But the offset will not let it fit the front. So you can drive around like a stunna have have 17's in the rear, and 14" steelies up.
[Modified by YodaIsGod, 11:52 PM 6/4/2002]
Old Jun 4, 2002 | 03:02 PM
guyuenvy's Avatar
you have to have 4 front s2000 wheels and it works if you have 5 lug conversion as I had s2k wheels on my integra
Old Jun 4, 2002 | 09:03 PM
ok 2 conflicting answers first guy says only rears fit second says only use front rims. So which is it? thanks and do you have pics of the s2000's on your teg? I don't know if it is gonna look good on a civic.
Old Jun 4, 2002 | 09:31 PM
Vanilla4215's Avatar
I think they mean only the front two s2000 wheels will fit because the rear s2000 wheels are wider then the front. If you put the rear s2000 wheel on then the tire and rim will stick out from your fender or quarter panel.
Old Jun 4, 2002 | 09:33 PM
Default Re: Need 5 lug help for s2000 wheels. (Vanilla4215)
alright cool how wide are the wheels anyway?
saadi
10
Dec 12, 2009 02:28 PM
ocyrus411
Jun 22, 2009 10:23 PM
96jdmaccord
Nov 7, 2005 05:36 PM
tRex99
Dec 28, 2004 03:06 PM
