another....car wont start....
Old Jun 9, 2007 | 01:39 PM
stuie08's Avatar
Default another....car wont start....
I searched but its one person says this and another this and i cant get any straight info., sorry im posting another one of these....
I have a 2000 integra gs-r, with 109k, and the only mod is a cat back exhaust.
Alright, so i was going to leave school yesterday and i go to start up my car. It starts up and then it was really bogging.
So i tried to give it some gas, and the car died.
Then i tried to restart the car but it would just turn over and try to start but it just wouldnt.
I tried jumping the car but that didnt help.
I have no clue what it is, i got my car towed and a shop said they cant look at it til monday....
If anyone has any ideas that i can try that would be great. Im just trying to get it running. Spark plugs? anything!! thanks a ton!!
Modified by stuie08 at 2:55 PM 6/9/2007
Old Jun 9, 2007 | 02:21 PM
InTeGrA_bLazEd's Avatar
could be the main relay.
Old Jun 9, 2007 | 03:10 PM
ls19integra95's Avatar
Default Re: another....car wont start.... (stuie08)
check your fuses because my buddies did the same and it was just his ignition fuse blew, also could be the main relay
Old Jun 10, 2007 | 09:33 AM
stuie08's Avatar
will check anyone think anything else?
Old Jun 10, 2007 | 09:42 AM
shiftyB18DC2's Avatar
Default Re: (stuie08)
i had this problem a few months ago, i first replaced the fuel filter, and it was fine for about a month, then it happened again, so i replaced the fuel pump, and it hasnt happened since then.
Old Jun 10, 2007 | 12:27 PM
stuie08's Avatar
yeah, but when i was trying to start the car and it was turning over but not starting it smelt like a ton of gas fumes..
Old Jun 10, 2007 | 02:21 PM
DurtyVdub's Avatar
fuel pump
Old Jun 10, 2007 | 08:00 PM
Default Re: (DurtyVdub)
if you can smell the fuel then you may not be getting spark, try holding a spark plug wire to a bolt head on your radiator support and have some one turn the engine over to see if you have spark getting to your plugs... if not then could be ground wire or most likely your distributor.
Old Jun 11, 2007 | 08:59 AM
stuie08's Avatar
so the shop said its my coil.. i read a lil about that but i already owe 80 for them finding the problem but $280 if i want them to fix it..... is this an easy fix??
Old Jun 11, 2007 | 09:17 AM
ziptie's Avatar
gl
Old Jun 11, 2007 | 12:29 PM
Default Re: (jagoff)
you can get just the coil for a whole hell lot less then that at an autozone or something like that...
Old Jun 11, 2007 | 12:32 PM
Rikter's Avatar
It's an easy fix for people who know how to work on cars but judging by the fact that you took it to a shop instead of worked on it yourself you should let the shop fix it for you.
-Rik
Old Jun 25, 2007 | 11:50 AM
bcrosby51's Avatar
Default Re: another....car wont start.... (Rikter)
Did you ever get your car running? I am having the same problem now. Car will turn over, just won't fire up. It has compression, spark and fuel pressure.
90crxdriver
Apr 17, 2008 05:12 AM
dragaholic
Aug 17, 2007 11:05 AM
91hatch86
Feb 19, 2006 10:52 PM
hatchy
Apr 3, 2003 06:50 PM
