Lowering my DA
Old Jun 9, 2007 | 01:24 PM
ballerchild's Avatar
Default Lowering my DA
I just installed a set of megan racing sleeveovers onto my stock shocks on my DA, and the front is the same height as stock!? I put the rings to lowest point and there's still about 2.5 inches of fender gap.. Is it the shocks that won't let me go lower? or did i do something wrong? I cut the bump stop in half, and used the little red tophat it came with..
Old Jun 9, 2007 | 03:05 PM
Old Jun 9, 2007 | 03:43 PM
super jdm yo's Avatar
Default Re: Lowering my DA (ballerchild)
did you put the dust cover back on? because that'll hit the sleeve and not let the shock come down all the way.
Old Jun 9, 2007 | 03:50 PM
Default Re: Lowering my DA (super jdm yo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super jdm yo &raquo;</TD></TR><TR><TD CLASS="quote">did you put the dust cover back on? because that'll hit the sleeve and not let the shock come down all the way.</TD></TR></TABLE>
is that the rubber piece underneath the tophat? if so yea, i put that over the red top the sleeves came with..
Old Jun 9, 2007 | 04:15 PM
anybody know what else the problem can be?
Old Jun 9, 2007 | 04:29 PM
anybody lowered on sleeveovers?
Old Jun 9, 2007 | 04:53 PM
Madness's Avatar
Are the sleeves the same front and rear? Reason I ask is, my buddy and I got a set of Megan springs for his EJ8 and they were mis boxed, fronts labeled rear and vice versa.
Old Jun 9, 2007 | 05:19 PM
Default Re: Lowering my DA (Madness)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madness &raquo;</TD></TR><TR><TD CLASS="quote">Are the sleeves the same front and rear? Reason I ask is, my buddy and I got a set of Megan springs for his EJ8 and they were mis boxed, fronts labeled rear and vice versa.</TD></TR></TABLE>
hmmm... never thought of that, i just installed them as they were labeled on the box.. i guess i gotta redo everything and recheck.
Old Jun 9, 2007 | 08:45 PM
everything looked good, the rear end is nice and dropped, but the front wont!? any other suggestions?
Old Jun 9, 2007 | 10:05 PM
i need to lower this car!!
Old Jun 10, 2007 | 09:14 AM
Default Re: (ballerchild)
Old Jun 10, 2007 | 05:25 PM
f22b2slow's Avatar
thats a crumy situation. I don't think the stock struts would be the problem. stock struts are a little longer because they have to travel farther, but unless your sleeveovers are 10" tall they shoudn't interfere. I know my stock struts came with the dust covers that went over the rod that travels into the strut. I had to take them off because they kept rattling when I hit a bump. Maybe they're not sitting right on the strut? Also, maybe the adjustable part on the sleeve is upside down. Not sure if it can be mounted like that, but I'm thinkin back to the ones I had and I think it's worth checking.
deeweezy187
Jun 16, 2005 02:15 PM
vtecpoweredsol
Suspension & Brakes
Apr 13, 2005 11:52 AM
Synthesis
Jun 23, 2003 10:55 AM
4potnick
Jun 5, 2003 05:44 PM
Mark
May 24, 2003 04:32 PM
