Lude won't turn over, thinking it's the fuel pump?
Old Jun 9, 2007 | 12:41 PM
1LEWDh22's Avatar
Default Lude won't turn over, thinking it's the fuel pump?
K so my buddy's a tech at a toyota dealership and i had him take a look and we narrowed it down to a fuel problem. A while back I was running nitrous and turned my fuel pressure up to 48psi from the stock 34 ( which i know was RETARDED) but we think i might have burned out my fuel pump. how hard is it to replace the fuel pump? I know you have to drain the gas tank and drop it out to get to the pump but I guess preludes (or hondas in general) have a gas tank bolt to easily drain out the fuel. any help would be great!
Old Jun 9, 2007 | 03:03 PM
lude98SH's Avatar
Default Re: Lude won't turn over, thinking it's the fuel pump? (1LEWDh22)
well i know on my 5th gen replacing the fuel pump was very easy actually. Pulled the rear seats and removed a bar going across the rear and its right there no need to drain fuel. There is a cover with screws i believe (its been awhile since i did it) and then once you remove that cover theres a few things to disconect off the pump then you remove a few bolts right on the top of the assembly and pull that sucker out. Real straight forward install, but thats if its the same as a 5th gen.
Old Jun 9, 2007 | 03:27 PM
Vtec_Dude's Avatar
yea just remove the rear seats.
Old Jun 9, 2007 | 05:06 PM
1LEWDh22's Avatar
awsome thanx guys! I already had my back seats gutted ( fiberglassing the rear) and was wondering if that might be it. I jus ordered a Walbro 255LPH fuel pump off ebay and it should be here by wednesday. I'll let you know if i run into any problems
Old Jun 10, 2007 | 01:08 AM
cb7tougeracer's Avatar
Default Re: (1LEWDh22)
my accord is gutted and i know if you turn the key in the on postion you can hear the fuel pump cut on try that
Old Jun 19, 2007 | 09:15 PM
1LEWDh22's Avatar
Default Re: (cb7tougeracer)
K i've run into a problem. The nuts on the fuel pump cover are totally rusted and basically desinigrate when i start trying to unbolt them. What do you guys recommend I do to remove them so I can replace my fuel pump and get the luda running?
Old Jun 19, 2007 | 09:19 PM
prelude_93vtec's Avatar
lol did u check your fuel pump relay? i ordered my fuel pump and found out it was only my relay and i didnt even have to change the fuel pump. i have a stock one if ure interesnted.
Old Jun 19, 2007 | 09:23 PM
1LEWDh22's Avatar
Default Re: Lude won't turn over, thinking it's the fuel pump? (prelude_93vtec)
no, but i've already got the new one-plus i figure since i bumped up my fuel pressure w/o upgrading my fuel pump or injectors it couldn't hurt. But i'll definately check out the relay. Where's it located and how can I tell if it's bad? Is it like a normal 5 tab,small black boxy lookin thing?
Old Jun 19, 2007 | 09:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1LEWDh22 &raquo;</TD></TR><TR><TD CLASS="quote">no, but i've already got the new one-plus i figure since i bumped up my fuel pressure w/o upgrading my fuel pump or injectors it couldn't hurt. But i'll definately check out the relay. Where's it located and how can I tell if it's bad? Is it like a normal 5 tab,small black boxy lookin thing?</TD></TR></TABLE>
cant help you on that. my mechanic did it for me
Old Jun 20, 2007 | 06:53 AM
Rob97'SH's Avatar
Try using a oil penatrator and if that doesn't work use vise grips.
Old Jun 20, 2007 | 07:39 AM
kacivic's Avatar
Default Re: (Rob97'SH)
yep, PB blaster has worked well for me
Old Jun 20, 2007 | 09:27 AM
AaronW's Avatar
It's located above your left knee under the dash on a LHD lude. The plug that goes into it is orange, and when you turn the key to the ON position, it makes a loud clicking noise, which you can feel if you hold it.
Unplug, put the new one in, zip tie the new one somewhere, and plug it in.
The old one is a pain to remove, I took mine out and resoldered the connections to fix it instead of replacing it.
You're probably better off just getting a new one and throwing it in there, leaving the old one in there, but disconnected.
Old Jun 20, 2007 | 09:43 PM
1LEWDh22's Avatar
UPDATE~ K so after a slight struggle w/ removing the rusted bolts and getting the fuel pump cover off i finally got the fuel pump out. but I ordered a Walbro 255LPH fuel pumps off ebay : http://cgi.ebay.com/ebaymotors...d=1,1 which was noticibley smaller than the stock one. But i got it swapped in and am just waiting to grab the cover nuts from honda tomorrow and we'll see how it goes.
-As for the relay, I checked it and there were no cracks at all in the soldered locations. but it was a HUGE pain in the *** to remove it. so many wires and i couldn't get my 1/4 ratchet up there to get it and ended up just popping it out of the case .
Old Jun 20, 2007 | 09:58 PM
ninja 6's Avatar
90 ef
Dec 2, 2009 05:33 PM
joeyt
Honda Civic (2001 - 2005)
10
Dec 24, 2008 10:40 AM
bigbacon2
Mar 3, 2006 02:52 PM
JeDPhelps
Feb 5, 2006 05:41 PM
trooper0641
Jul 13, 2005 08:21 PM
