Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Rear "H" emblem pins
Old Jun 9, 2007 | 12:00 PM
a1staecksauce's Avatar
From: Westminster/Huntington Beach/Seal Beach, CA, United States
Default Rear "H" emblem pins
so today I tried to install the rear JDM "H". I started off by using the dental floss but it got stuck. I looked under the trunk and found two white plastic pins that hold the "H" on. They're the kind you can just twist off, but they're stuck really tight. I tried everything to get 'em off. Has anyone else ran into this problem, and if so how did you get them unscrewed? I have a 2007 civic coupe lx. Blue Rocket did a D.I.Y. on this but didn't say anything about pins under the trunk lid. Maybe cause he has a SI?
Old Jun 9, 2007 | 12:17 PM
FG2 chilotz's Avatar
Default Re: Rear "H" emblem pins (a1staecksauce)
I have a 07 SI coupe and well I too have those little numbs on the other side of my trunk. As far as taking your emblem off you need to get a needle nose plier and squeeze the little nipples so they can release the emblem of course after heating the emblem with a heat gun or blow dryer. Good luck to your JDM H install.
Old Jun 9, 2007 | 12:58 PM
Default Re: Rear "H" emblem pins (FG2 chilotz)
thanks, i'll try that.
Old Jun 9, 2007 | 03:31 PM
Demonis's Avatar
heat it? why?
I just used floss to separate the adhesive from the paint, then the only thing that holds on the emblem is the pins.
Push out the pins as mentioned above, the new red h will not fit these holes, very easily pull off the white part with the black seal ring... place these in the holes to seal it from water, then clip off the leftover black pins. Alignment is tricky but do-able.
Old Jun 9, 2007 | 07:42 PM
now_thats_JDM!'s Avatar
I took the old nipples off my emblem grinded the excess plastic flush and used emblem adheasive to attach to my car. it hold better than that crappy double sided tape.
Old Jun 9, 2007 | 08:57 PM
Default Re: (Demonis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">heat it? why?</TD></TR></TABLE>
It wll soften the adhesive and make it easier to remove the emblem. Heat makes it come off easier!
Old Jun 10, 2007 | 08:51 AM
cashdealer07's Avatar
is EX the same? do they have the pins?
Old Jun 10, 2007 | 01:58 PM
Default Re: (cashdealer07)
yes, they are all the same. this is what I did.
1. get fishing line and cut the adhesive from the bottom up to the pins.
2. then, with the fishing line, pull straight out/up depending on what angle you have the trunk at. This
should cause the emblem to pop right up out of the pins.
3. Then just pull the emblem off or cut the adhesive with the fishing line.
4. The stick the new JDM "H" on.
This was much easier than trying to pull the pins off from the underside. Thats pretty much impossible.
Old Jun 10, 2007 | 05:47 PM
will_rex's Avatar
If you use the floss to seperate, you can just pull on the emblem and it will pop off. Don't be afraid to use some force. Otherwise, take off the interior trunk panel and release the tabs from the inside after seperating the adhesive.
thewrai6th
Jul 17, 2018 10:43 PM
Byron Doyle
Mar 19, 2018 02:12 PM
arjnmrskr213
12
Jan 29, 2017 05:39 PM
EvilEyez
Audio / Security / Video
13
May 29, 2007 06:19 PM
optikal_blitz
Jan 10, 2003 01:22 PM
