LS into 91 HF
you sure can
but are u goin to convert it to obd1 if im not mistaking the 92 and 93 integras are obd1 and the rex is obd0 so whats ur plans on that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 »</TD></TR><TR><TD CLASS="quote">you sure can
but are u goin to convert it to obd1 if im not mistaking the 92 and 93 integras are obd1 and the rex is obd0 so whats ur plans on that?</TD></TR></TABLE>
Yes it'll be an obd1 motor but can be run obd0 or obd1.
Good post
but are u goin to convert it to obd1 if im not mistaking the 92 and 93 integras are obd1 and the rex is obd0 so whats ur plans on that?</TD></TR></TABLE>Yes it'll be an obd1 motor but can be run obd0 or obd1.
Good post
92 93 integra is not obd 1- it is obd0 b18a1 and i have a 91 hf with a ls in it from a 93 teg and u have to use the harness because the igniter points are diffrent and the car wont spark, i found that out the hard way lol. tegs went obd1 in 94 with the b18b1 and yes ur best bet if ur going turbo is to run obd 1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1stgenboost »</TD></TR><TR><TD CLASS="quote">92 93 integra is not obd 1- it is obd0 b18a1 and i have a 91 hf with a ls in it from a 93 teg and u have to use the harness because the igniter points are diffrent and the car wont spark, i found that out the hard way lol. tegs went obd1 in 94 with the b18b1 and yes ur best bet if ur going turbo is to run obd 1</TD></TR></TABLE>
I know for a fact 93 integra's are OBD1 I think 92 is also, my LS swap was a 93 and it was OBD1
