Timing belt question
Old Jun 9, 2007 | 09:50 AM
shit's Avatar
Default Timing belt question
For my 95 Civic DX, does anybody know what I'm suppose to set the timing at? Sorry, but I haven't had much time to search, I have to be at work in two hours
Old Jun 9, 2007 | 09:52 AM
94hatchling's Avatar
Default Re: Timing belt question (SleeeeepyDX)
are you wanting ignition timing or cam timing?
make sure the crank pulley is aligned, and the cam gear to positioned properly. both have marks to tell you where TDC is.
I just find it easier to set TDC before i take the belt off, lock in the cam gear so it doesnt move, and then slap it back together. a little late for that though.
and FYI... there is a FAQ in the FAQ thread that will tell you everything you need to know. so no time wasted waiting for someone to reply.
Old Jun 9, 2007 | 09:58 AM
shit's Avatar
Default Re: Timing belt question (94hatchling)
I'm wanting cam timing... The car starts up just fine, but it makes this rapid idling noise. Do you think that I didn't set the timing right?
And I'll check the FAQ next time, thanks
Old Jun 9, 2007 | 12:17 PM
TooManyTickets's Avatar
if its running then the timing cant be very far off.
where is the noise coming from? the timing belt area or the valve cover?
if its the valve cover? did you do a lash adjustment on the valves?
flipldls
Jun 6, 2010 08:45 PM
crxblues
10
Apr 9, 2009 10:00 AM
EX-T
Jan 27, 2009 09:22 AM
civickiller
Mar 8, 2004 11:34 AM
P1mpSlap
Jul 24, 2003 10:46 AM
