AC from 95 work in 92 civic? need help ASAP!!!
i was told theres a difference with r12 and r134 or whatever it is.
But basically, im taking all the AC components from the engine bay of a 95 civic, and hooking it up to the firewall of a 92 civic
Modified by See Are X at 1:54 PM 6/9/2007
yes thats correct. sorry man, that completely slipped my mind. Honda switched to R134a in 1994. BUT switching to a 95 a/c system would be in your best interest since it will be completely R134a and you won't have to do a retrofit.
R12 is expensive... literally. but works much more efficiently than the newer R134a. So if your checkbook can afford it, R12 will cool better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X »</TD></TR><TR><TD CLASS="quote">so would the lines from the 95 civic bolt up to the connections at the firewall on the 92 civic?</TD></TR></TABLE>
Yes, just make sure everything is clean if it used and is being bolted up to the original '92 equipment if there is any left.
the oil used for R12 does not mix with R134a AT ALL.
i cleaned out the evaporator with an air compressor but no ac flush, not sure what that is. What exactly is "drier"???
also, does anyone know if the civics that did not come with AC, are wired for AC???
Modified by See Are X at 6:25 PM 6/9/2007
actually, the 92-3 civics have completely different ac systems. the 92-3 ac system uses 12mm bolts to connect the high and low pressure lines to the compressor which means 8mmx1.25 threaded holes in the compressor. the 94-5 uses 10mm bolts. the same goes for the lines that connect to the evaporator, the 92-3 uses a 10mm for the high pressure line and a 12mm for the low. the 94-5 uses a 10mm for the high and a 10mm for the low. the best thing to do is buy all lines and compressor from a 92-3 so everything bolts up. then buy a new drier and pick up the r134a converion kit for 10 bucks at autozone which consists of the r134a fittings that screw right onto your r12 lines then flush and evacuate the system, draw it to a vacuum and charge it with r134a
thewrai6th
Jan 9, 2008 11:56 AM
