can I remove the radiator fan switch with coolant still in the car
Old Jun 9, 2007 | 08:22 AM
LukieLuc's Avatar
Default can I remove the radiator fan switch with coolant still in the car
Do I have to emty out the radiator to change the radiator fan switch or can I do it with fluid still in there, but with the motor cold?
Old Jun 9, 2007 | 09:04 AM
sickcord's Avatar
Default Re: can I remove the radiator fan switch with coolant still in the car (LukieLuc)
yes its just screwz that hold ur fan on and disconter the conneter
Old Jun 9, 2007 | 10:21 AM
LukieLuc's Avatar
Default Re: can I remove the radiator fan switch with coolant still in the car (sickcord)
Not the fan, I want to take out the coolant temperature switch, its the sensor that is on the rad....hose when it goes into the head of the motor, can I remove it with out emptying out the coolant
Old Jun 9, 2007 | 04:49 PM
street_ride14's Avatar
Put a rag under it and start to remove. you'll figure it out from the way the next 30 seconds come out to be.
Old Jun 9, 2007 | 09:06 PM
BB1 H22A LUDE's Avatar
In my experience the best way to do it is to remove just like 500ml - 1L of coolent.
Just pull the plug from below the radiator drain a little bit then remove the temp sensor. U could try a rag but it doesn't work that well and u end up with coolent all over the tranny, block and engine bay and its hard to clean it, ie tight space to clean.
redbull99
Aug 27, 2015 10:19 AM
phoxking
13
Apr 15, 2011 03:47 PM
b18Aaron
86
May 8, 2010 10:03 PM
Lloyd Xmas
Nov 3, 2009 05:51 AM
Twistedframe
May 24, 2007 08:26 AM
