Skunk2 Pro intake manifold b16 Idle surge
Hey sup people i need your expertise on this one ht, last night i had just installed a brand new Skunk2 Pro intake manifold on my obd1 b16. I removed everything accordingly and went ahead and started to transfer all the original parts to the new Manifold, got done put everything back together, changed the intake manifold the tb gasket seemed to be as good as can be, connected all the wires made sure all hoses were connected, BUT forgot one! it was on the PCV box, i believe that is what it is called (the black box thing under the intake manifold) started the car and got this really fast idle surge from 1000 - 3500 rpm. Usually when this happens i thought i might have switched the tps and map sensor, check again and it wasnt. SO....i was wondering would the connection to the pcv box cause this? LMK PEOPLE THANKS!
Modified by tealj1 at 2:29 PM 6/9/2007
Booo on your ***. You forget to hook **** up, have all the signs of a huge vacuum leak that a simple search would show you and want 'help'?
Hook **** up. Correctly. Get back to us after you've done that.
RocHatchDX
24
Jun 17, 2013 12:55 PM
Ep1dem1c
Jul 18, 2007 10:03 AM
egjdm03
Feb 11, 2004 02:26 PM
Eggman
Jan 28, 2002 06:25 PM
