Oil pressure problem Fresh build
Old Jun 8, 2007 | 10:56 PM
imptricer's Avatar
Default Oil pressure problem Fresh build
just got done building my b20/v and started it 2 days ago it had decent oil pressure but not the best somewhere around 20-25 at ilde so i drove it and at like 3-4k it would have around 50-65 psi of oil pressure. so i only have like maybe 10 miles on the motor. so today i was driving it and completely lost all oil pressure and have no clue why??? i disconnected the oil line coming from my samewich plate to the head and cranked it off not even a drop of oil???? i am really speechless to why all of the sudden i lost me volume???? has anyone had this problem im going to start doing to look more into it 2maro and start pulling the oil pan and oil pump!
I did shut it off immediately when there was no oil pressure i checked the oil looks good so can anyone help me thanks
Old Jun 9, 2007 | 10:36 AM
imptricer's Avatar
Default Re: Oil pressure problem Fresh build (imptricer)
bump i searched for like hr hours trying to find out if other people have had this problem and i found like two people one there pressure relief valve was stuck open and the other was the pump but these weren't on fresh engines so anyone have a clue????
Old Jun 9, 2007 | 10:39 AM
inspyral's Avatar
The first thing that comes to mind is the oil pickup nuts/bolts may have backed out, or the pickup might be clogged
Old Jun 9, 2007 | 10:53 AM
imptricer's Avatar
Default Re: (inspyral)
thanks alot i am just going to pull the oil pan here in the next hour ill keep you posted!!!! anyone else have any ideas
Old Jun 9, 2007 | 02:26 PM
imptricer's Avatar
Default Re: (imptricer)
one of the bolts from the pick up was in the pan!!! **** but i checked the bearings and now have to get new ones there not that bad but should wear for only 5-8 miles lol there were metal shavings in the bottom of the pan so i debating what to do b/c i need my car running by friday. i was thinking of have my crank polished and puttting new bearings in. but could just that bolt coming out lose all of my oil pressure?
Old Jun 10, 2007 | 12:43 AM
imptricer's Avatar
anyone think it was sucking air from where it bolts to the pump since the bolt was out and thats why i lost all oil pressure?
Old Jun 10, 2007 | 11:58 AM
imptricer's Avatar
Old Jun 10, 2007 | 12:43 PM
non-VTEC's Avatar
hmmm.....if the main bearings were starved of oil then chances are they may have damaged the crank as well......you can try to quickly tighten up that oil pickup bolt and run the engine again and see if it builds oil pressure....
bearing damage can happen so quickly when there is no oil....but its hard to give you any kind of good advice without seeing the engine.
i guess if it were mine i would pull the engine and send it back to the machine shop and have them inspect it. also have the oil pump checked out too.
Old Jun 10, 2007 | 12:49 PM
imptricer's Avatar
Default Re: (non-VTEC)
i spun #4 main so ya lol going to have it ground .10 under and get new bearings next day aired and have the oil pump checked out for sure
Old Jun 10, 2007 | 12:52 PM
4g hatch's Avatar
oil pump could have got air locked from sucking the air in. did you plastigauge your bearings to see if they were in spec
Old Jun 10, 2007 | 12:58 PM
imptricer's Avatar
Default Re: (4g hatch)
very close to spec ya when i put it together i cleaned all the oil and water galleys so it had to have been from sucking air from where the pick-up tube and oil pump meet. im grinding the crank so i know they will all be the same and then plastigauging when i go back together on wedsneday
Old Jun 10, 2007 | 06:14 PM
4g hatch's Avatar
how much is he taking off the crank
Old Jun 10, 2007 | 11:10 PM
imptricer's Avatar
its going to be .010 undersize i believe
an2ny888
May 6, 2013 10:31 AM
eg-gsr423
Oct 27, 2009 08:57 AM
fr3dy_1
17
May 23, 2008 11:33 PM
boost'dsiR
Jul 20, 2005 02:44 PM
EG*MonKEY
Nov 11, 2002 09:57 PM
