need help please was wondering if its ok to use the ASR brace after the beaks kit?
From: Where the shooting range is on the streets of LA, CA.
ok guys well my current setup is the old skool beaks reinforcement kit for the EK, i have the oem CTR 22mm sway bar on it...
Now i wanna upgrade but im holding back because i dont know if the ASR brace will require for me to drill holes again into my subframe... but for those who run a beaks reinforcement kit like myself i had to drill holes, obviously... now my question is
WILL THE ASR BRACE BOLT RIGHT UP TO THE HOLES I ALREADY MADE FROM THE BEAKS KIT OR WILL I HAVE TO DRILL KNEW ONES?
AND IF I DO, DID I MESS MY CHANCES UP OF INSTALLING THE ASR BRACE BECAUSE THE HOLES THAT I NEED TO MAKE WILL SOME HOW INTERFERE WITH THE PREVIOUS HOLES MADE FROM THE BEAKS KIT?
i just dont wanna buy somthing that i wont be able to use...
thanks in advance guys i really appreciate it!
Check it out: https://honda-tech.com/zerothread?id=1906897
you would not need to use the beaks after you put on the ASR. Those holes you drilled will be covered by the new subframe. No need to worry about the new ASR not being able to fit or having to drill more holes. ASR will bolt up using the OEM bolt points.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by termistTM1 »</TD></TR><TR><TD CLASS="quote">you would not need to use the beaks after you put on the ASR.</TD></TR></TABLE>
thanks man!!! but i knew i didnt have to use the "beaks kit" after i put on the ASR brace... i just wanted to know about fitmint and you answered it. thanks man!
confucioussae
Sep 5, 2006 05:04 AM
