BSQ Mounting Kit Users..
Old Jan 3, 2003 | 08:06 PM
navin's Avatar
Default BSQ Mounting Kit Users..
Hey Guys,
I have emailed Bret once and I got a reply, but I could not get the answer I needed from it and I am sure he is busy so I thought I'd ask the users of his kit 1st hand.
Does Bret's kit use any of the mounting hardware on the inside of the subframe, the problem I am having is that I have the Beaks SRK kit and I have spot-weld'd ABS nuts inside the subframe. And they need to be removed, but I cant get the boogers out.
So I thought maybe I can just switch over to BSQ...
Old Jan 3, 2003 | 08:23 PM
integ22's Avatar
Default Re: BSQ Mounting Kit Users.. (navin)
I believe with either kits you will need to take off those welded nuts. I am using the BSQ kit. I just unscrewed the bolt that's connected to the nut (about halfway), then hit that bolt HARD to break the welds. HTH
Old Jan 3, 2003 | 08:26 PM
navin's Avatar
Default Re: BSQ Mounting Kit Users.. (integ22)
I guess I'll give it another go tommorow...
Old Jan 3, 2003 | 10:32 PM
lshobo's Avatar
for BSQ's kit, you only need to take off 2 of those spot-welded nuts, I believe. Chisel and mallet or driving the bolt through to knock it off should suffice as Bret suggested.
Old Jan 3, 2003 | 11:06 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: BSQ Mounting Kit Users.. (lshobo)
Unscrew the bolt from the other side a little, and pound on it hard with a hammer. It will start to bend out the spot welded nuts. Then you can pry at them from the other side.
Good luck. You do have to hit them quite hard.
Old Jan 3, 2003 | 11:07 PM
Pat's Avatar
Pat
I found the spot welded nuts easier to chisel off if you drill through them first ie: do the step where you drill to enlarge the holes first.
Old Sep 12, 2005 | 10:05 AM
BlueTeg's Avatar
Default Re: BSQ Mounting Kit Users.. (Pat)
What angle are you guys hitting the bolt head to remove the spot welded nut? i.e. are you hitting the head of the bolt like a nail or from various "side" angles?
Old Sep 12, 2005 | 10:16 AM
SMZ GSR's Avatar
Default Re: BSQ Mounting Kit Users.. (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">You do have to hit them quite hard.</TD></TR></TABLE>
That's an understatement I had to hit mine hard as **** to get them out. lol
Old Sep 12, 2005 | 10:32 AM
BlueTeg's Avatar
Default Re: BSQ Mounting Kit Users.. (SMZ GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMZ GSR &raquo;</TD></TR><TR><TD CLASS="quote">
That's an understatement I had to hit mine hard as **** to get them out. lol</TD></TR></TABLE>
At what angle did you hit them hard as ****?
Old Sep 12, 2005 | 10:44 AM
SMZ GSR's Avatar
Default Re: BSQ Mounting Kit Users.. (BlueTeg)
Straight on.
Old Sep 12, 2005 | 02:02 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg &raquo;</TD></TR><TR><TD CLASS="quote">At what angle did you hit them hard as ****?
Straight on like it's a nail. Unscrew it a little so there's like 1/4 inch off. Then just hammer it HARD. It'll start to go screwy as you get it and go off at an angle. At that point, you'll see the spot welded nut start to separate from the subframe. As it does, do what you gotta do to get it off (pry a screwdriver into it, vice grips, etc).
Good luck. Make sure you got some good jackstands under there so when you whack it, nothing falls on j00.
Old Sep 12, 2005 | 03:46 PM
spender1326's Avatar
I found the chisel method to be safer. I did the screw out and pound with hammer hard method and the subframe bent in slightly. I guess the spot weld were really strong on my car. So after that, I chiseled. Once you get one of the 4 spots out, its a piece of cake. But getting the first one out does take some fine chisel work.
Old Sep 12, 2005 | 04:33 PM
vtecmissle's Avatar
you can get most of it with a unibit. Very little work afterwards.
thrty8street
Aug 28, 2015 04:29 PM
immortal
Honda Motorcycles
May 31, 2007 03:25 PM
Astig
Mar 16, 2007 05:23 PM
zizux
Jun 1, 2006 11:41 AM
