Rear sway bar options - 26mm+
Old Jun 8, 2007 | 07:39 PM
TPB's Avatar
TPB
Default Rear sway bar options - 26mm+
What manufacturers offer rear itr sway bars that are 26mm or larger... adjustable or non-adjustable? I know there is Mugen, but I'm not interested in paying for the name and the marketing hype that surrounds it. No need to tell me how much oversteer, etc. this is for a track only car with very high spring rates (1,000 lb+).
cheers
Old Jun 8, 2007 | 07:42 PM
JjuuN R's Avatar
Default Re: Rear sway bar options - 26mm+ (TPB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TPB &raquo;</TD></TR><TR><TD CLASS="quote">high spring rates (1,000 lb+).</TD></TR></TABLE>
Right... It's hard to find the Mugen 26mm anyway. A Spec Racing (ASR) makes a 32mm adjustable one, you can purchase it from King.
Old Jun 9, 2007 | 03:59 AM
itrdave's Avatar
Default Re: Rear sway bar options - 26mm+ (JjuuN R)
I believe ASR makes about the only bar that is 26 mm + stiff other than Mugen. If 25 mm will work for you - look at the Cusco non-adjustable for about $250.
Old Jun 9, 2007 | 05:00 AM
cjames235's Avatar
Default Re: Rear sway bar options - 26mm+ (itrdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrdave &raquo;</TD></TR><TR><TD CLASS="quote">look at the Cusco non-adjustable for about $250.</TD></TR></TABLE>
little high jack sorry but where can i find this? ive been on the hunt for one for a while now and finding a good place that sells cusco is not that easy
Old Jun 9, 2007 | 12:12 PM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">
Right... It's hard to find the Mugen 26mm anyway. A Spec Racing (ASR) makes a 32mm adjustable one, you can purchase it from King.</TD></TR></TABLE>
What's so hard to believe? You can see from his avatar that it's a race car.....
Old Jun 9, 2007 | 03:19 PM
Circuit Star-29's Avatar
Default Re: Rear sway bar options - 26mm+ (Black R)
Alex Motorsports also makes a 25mm Rear sway bar.. Its pricey, at $380, but if you want it, price doesn't matter...right? Personally, I'd like to try it out.
http://www.aj-racing.com/catal...age=5
Old Jun 9, 2007 | 09:37 PM
white rocket's Avatar
Default Re: Rear sway bar options - 26mm+ (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">Alex Motorsports also makes a 25mm rear sway bar</TD></TR></TABLE>
That's what I run.....works for me......
Old Jun 11, 2007 | 09:05 AM
TPB's Avatar
TPB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
What's so hard to believe? You can see from his avatar that it's a race car..... </TD></TR></TABLE>
Correct:
I'm looking into the asr 32mm bar - thanks for the heads up.
Old Jun 11, 2007 | 09:21 AM
Team Bukkake Sucks!!!'s Avatar
The ASR 32mm bar is hallow. It is not as stiff as you might think. Of course depending on a lot of other factors, torsional stiffness should be about the same as a 25mm,26mm solid bar
Old Jun 11, 2007 | 09:37 AM
TPB's Avatar
TPB
Default Re: Rear sway bar options - 26mm+ (Team Bukkake Sucks!!!)
Going for the 1/4" wall thickness which does make a significant difference.
itr1244's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team Bukkake Sucks!!! &raquo;</TD></TR><TR><TD CLASS="quote">The ASR 32mm bar is hallow. It is not as stiff as you might think. Of course depending on a lot of other factors, torsional stiffness should be about the same as a 25mm,26mm solid bar</TD></TR></TABLE>
lol who says hollow bars are "less sitffer" than solid?
go study some more of strength of materials
Old Jun 11, 2007 | 07:34 PM
Default Re: Rear sway bar options - 26mm+ (itr1244)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 &raquo;</TD></TR><TR><TD CLASS="quote">
go study some more of strength of materials</TD></TR></TABLE>
I do. see for your self
http://www.whiteline.com.au/do...r.pdf
Although they are lighter weight. Holow sway bars have to have a much larger OD to have the same torsional strenght/stiffness that a solid sway bar with a much smaller OD would have
Old Jun 12, 2007 | 06:26 AM
SMSP's Avatar
Torsional stiffness is determined by
Do: Outside Diameter
Di: Inside Diameter
Do^4 and Di^4
So for a solid bar the factor is Do^4
For a hollow bar it's (Do^4 - Di^4)
Then just compare the two (Do^4 - Di^4) hollow/Do^4 solid
So a 32mm OD bar with a 2mm wall is 11% stiffer than a 25mm solid bar. Change the wall thickness to 3mm and the hollow bar is now 51% stiffer.
Bottom line: small diameter bars and the core of large diameter solid bars do very little.
Go ASR.
Old Jun 12, 2007 | 08:47 AM
Default Re: Rear sway bar options - 26mm+ (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">Torsional stiffness is determined by
Di: Inside Diameter
Do^4 and Di^4
Go ASR.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team Bukkake Sucks!!! &raquo;</TD></TR><TR><TD CLASS="quote"> The ASR 32mm bar is hallow. It is not as stiff as you might think. Of course depending on a lot of other factors, torsional stiffness should be about the same as a 25mm,26mm solid bar</TD></TR></TABLE>
Like i said earlier the 32mm hallow bar is about the same stiffness as a 25-26mm solid bar
Old Jun 12, 2007 | 11:00 AM
SMSP's Avatar
Like i said earlier the 32mm hallow bar is about the same stiffness as a 25-26mm solid bar</TD></TR></TABLE>
No it's not. Do the math.
The ASR 32mm bar has a wall thickness of 2.5mm so it's 32.4% stiffer than the 25mm solid bar and 13.2% stiffer than a 26mm bar. Also the solid bars weigh about 2x that of the hollow bar. So if you want something that's less stiff and weighs alot more than go with a solid bar.
Old Jun 12, 2007 | 11:15 AM
itrdave's Avatar
Default Re: Rear sway bar options - 26mm+ (cjames235)
Got mine from intakeone.com last August
Old Jun 12, 2007 | 01:11 PM
Black R's Avatar
25 Year Member
The ASR 32mm bar has a wall thickness of 2.5mm so it's 32.4% stiffer than the 25mm solid bar and 13.2% stiffer than a 26mm bar. Also the solid bars weigh about 2x that of the hollow bar. So if you want something that's less stiff and weighs alot more than go with a solid bar.</TD></TR></TABLE>
So in short, ASR ftmfw!!11
Old Jun 12, 2007 | 01:35 PM
Shame on me for not doing my research on the ASR bar. I had no idea the wall thickness was 2.5mm
GUILOTINE
Jan 26, 2006 09:51 AM
xsists
Suspension & Brakes
Aug 4, 2005 09:33 AM
juntuned
Jun 13, 2005 08:08 PM
Flux
Aug 11, 2003 04:19 PM
jr_istheman
Jun 4, 2003 08:33 PM
