service check signal wire?
Old Jun 8, 2007 | 07:18 PM
Hondamonster's Avatar
Default service check signal wire?
did an obd1 conversion... where do i hook up the scs wire?
Old Jun 8, 2007 | 07:51 PM
Default Re: service check signal wire? (Hondamonster)
anybody? i just want to make my cel work in case i have some kind of problem
Old Jun 9, 2007 | 11:16 AM
bump
Old Jun 9, 2007 | 05:51 PM
bump. 30 views and nothing... is this because nobody uses this wire??? i want to do it right, so where do i hook the service check signal wire? please?
Old Jun 9, 2007 | 10:16 PM
sanimalp's Avatar
$cat /dev/urandom
i believe that if you got a rywire conversion harness, there are a couple extra wires in the 4 wire o2 adaptor harness that you can cross to check it.. but unfortunately i dont know exactly which wires they are..
if you dont have a rywire adaptor harness.. then you should look in a manual to figure out which wires get shorted to the ecu to blink your CEL.
sorry.. thats all ive got..
Old Jun 10, 2007 | 12:46 AM
ef92b's Avatar
pin D4 (Brown wire)
pin D22 (Green/ White wire)
Chaosgrunt
Mar 13, 2019 06:23 PM
xesvuli420
Aug 7, 2013 07:39 AM
D16Z6racing
Audio / Security / Video
Mar 21, 2007 05:56 AM
streetstylenperformance
Feb 26, 2004 03:28 PM
