new swap and now transmission problems
Old Jun 8, 2007 | 06:50 PM
92integracer's Avatar
Default new swap and now transmission problems
I just put a B18B into my crx si and now the transmission is leaking pretty bad. It seems to be leaking from the back like where the linkage is connected or above that. This is suprising because I tightened everything to spec. I have noticed that if let off the accelerator I can hear the transmission moaning and at low speeds if I keep a constant pedal pressure, the car will start lurching. When I let off the pedal there seems almost like there is a resistance. I took the dust plates out and I don't think it is the axels, but I need some ideas of what this is because I am away from home and my tools so I can't check it out by myself.
thanks
Old Jun 8, 2007 | 07:32 PM
Hondamonster's Avatar
Default Re: new swap and now transmission problems (92integracer)
do you know if the tranny had problems from wherever you got it?
Old Jun 8, 2007 | 10:58 PM
sirhavok's Avatar
its the throttle speed sensor in there tight?
Old Jun 10, 2007 | 12:31 AM
do you mean the sensor on top of the tranny that shows rpm and speed? It is in there good but no c-clamp on it. I don't know if there were problems before i got the transmission, it was already pulled from a car.
Black90CrxSi
Feb 14, 2009 03:14 PM
4jackstands
Oct 24, 2005 10:26 PM
H.crx-si
Jun 15, 2004 04:04 AM
92LudeSI
Dec 10, 2003 07:24 AM
DLOTYPER
Aug 14, 2003 07:13 PM
