hasport ac bracket
Old Jun 8, 2007 | 05:29 PM
crxdxsir's Avatar
Default hasport ac bracket
I just installed my hasport a/c bracket, and my compressor seams to be resting on my crossmember, anyone else have this problem? and if so how they fixed it? thanks for any help i can get.
Old Jun 8, 2007 | 05:39 PM
abnaasefmb's Avatar
Default Re: hasport ac bracket (crxdxsir)
no, mine fit perfect.
Old Jun 8, 2007 | 07:44 PM
crxdxsir's Avatar
Default Re: hasport ac bracket (abnaasefmb)
hmmm ok. I will have to look at it closer. do you know what compressor you have? My instructions listed 2 differant compressors.
Old Jun 9, 2007 | 12:54 AM
crxnj's Avatar
I had a sanden compressor and it was a tight fit but it fit. I think the other one is matshusuta or something like that? don't know if its different or what
Old Jun 9, 2007 | 06:06 AM
crxdxsir's Avatar
Default Re: hasport ac bracket (crxnj)
I have the matsushita compressor. not sure what to do. it makes a horrible vibration. :/
Old Jun 9, 2007 | 06:41 AM
abnaasefmb's Avatar
did you use the right spacer?
Old Jun 9, 2007 | 07:36 AM
crxdxsir's Avatar
yeah, the spacer just made one hole flush with the other three. Im not sure whats goin on. Do you think i need to use hasport motor mounts or something?
Old Jun 9, 2007 | 09:02 AM
Bob_760's Avatar
I wouldn't say you can't use non hasport mounts with that bracket necesarily. However fitment is all about engine placement. If the mounts you have put the engine in a place that when you bolt on the ac compressor it hits your crossmember... Then yes, I would assume your engine placement won't work with that bracket and you need at the least different mounts. Unless you're putting the bracket on wrong or something, but it's an a/c bracket there isn't much to it. I don't know what mounts have what kinda engine placement but I know hasports put the motor tward the back of the engine bay compared to most so that would give lots of room for your a/c. Alternately have you considered getting an aftermarket crossmember? That would probably solve your problem too.
Old Jun 9, 2007 | 09:24 AM
danmdevries's Avatar
Default Re: hasport ac bracket (Bob_760)
Bust out the BFH and pound your crossmember into submission.
Old Jun 9, 2007 | 09:57 AM
crxdxsir's Avatar
Default Re: hasport ac bracket (danmdevries)
ya i am thinkin hammer or saw, untill i get the aftermarket crossmember. I believe i got the avid mounts. It has to be just barley hiting the member, cause it went on smoothly. thanks for all the info fella's. have a great weekend!
Jesterian
Aug 18, 2006 01:26 AM
RaysBoomBoomLude
27
Aug 24, 2005 07:54 AM
VAAJ
Mar 26, 2004 11:17 PM
Jesse H
Sep 7, 2002 08:24 AM
