dualpoint to multipoint info
Old Jun 8, 2007 | 03:59 PM
totoshatch's Avatar
Default dualpoint to multipoint info
i just recently purchased an 88 honda hatchback shell, it has a pr5 computer and someone wrote 89 si with a marker on the computer. i also boght a 92 16valve hatchback motor to install on this hatch, the motor harness has grey pigtails and the car has milky white pigtails. ive been told that a harness for a 89 crx si will bolt right up to my engine and car. is this correct? i already changed the tranny to cable so that it could work on the car. pleas help me its my first honda swap so i have no idea if this is correct
Old Jun 8, 2007 | 05:00 PM
obd1_crx's Avatar
yes. as long as you have the obd0 distributer, throttle body, intake, resister box, and o2 sensor. i beleave that is all to change the obd1 motor to obd0 parts.
Old Jun 8, 2007 | 06:19 PM
totoshatch's Avatar
Default Re: (obd1_crx)
what about the computer that i have will that work too?
Old Jun 8, 2007 | 07:35 PM
slow_rex_will's Avatar
Default Re: (totoshatch)
Correct ECU would be a PM6.
Old Jun 8, 2007 | 07:43 PM
Targa250R's Avatar
be professional
Default Re: dualpoint to multipoint info (totoshatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totoshatch &raquo;</TD></TR><TR><TD CLASS="quote">i just recently purchased an 88 honda hatchback shell, it has a pr5 computer and someone wrote 89 si with a marker on the computer.</TD></TR></TABLE>
The PR5 isn't exactly from an "89 Si", but it is interchangeable. USDM D16A6es ran a PM6. The PR5 is a SOHC ZC ECU from a pre-OBD JDM DA Integra, so it is similar to a PM6.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i also boght a 92 16valve hatchback motor to install on this hatch</TD></TR></TABLE>
If it's a D15B7, most of those blow headgaskets. Are you sure the engine didn't have a bad head gasket before it was pulled?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the motor harness has grey pigtails and the car has milky white pigtails. ive been told that a harness for a 89 crx si will bolt right up to my engine and car. is this correct?</TD></TR></TABLE>
The D16A6 engine harness will not plug into an '88 hatchback chassis harness, because all USDM '88 Civic hatchbacks had dual-point fuel injection. The D16A6 Si engine had multi-point fuel injection, and the harness connector pinouts are different. What you have to do is convert the '88 hatchback harness to run MPFI with bits from the Si harness.
Old Jun 8, 2007 | 09:10 PM
EFHATCHMAN's Avatar
Default Re: dualpoint to multipoint info (Targa250R)
HEY I JUST SO HAPPEN TO HAVE A COMPLETE MPFI SETUP FOR SALE... LET ME KNOW IF YOU'RE INTERESTED.
I ALSO HAVE THE PM6 ECU THAT YOU WILL NEED FOR THIS PROJECT.
ILL MAKE YOU A HELL OF A DEAL ON IT... SEND ME AN INSTANT MESSAGE.
THANKS!!
Old Jun 8, 2007 | 09:43 PM
Targa250R's Avatar
be professional
Default Re: dualpoint to multipoint info (EFHATCHMAN)
Trial users can't PM, and this isn't the Marketplace.
Old Jun 9, 2007 | 05:41 AM
totoshatch's Avatar
the motor im installing has a d15 block with a d16vtech head, is that the engine that has head gasket issues? i was looking at a forum that gives direction on how to convert it to mpfi it says that i can use the motor harness from dpfi but i have to add two injector clips and a ressistor box. whats the best way to do it, buy an si harness or make mine work? im going to look for one now
Old Jun 9, 2007 | 05:59 AM
EFHATCHMAN's Avatar
Just use your harness and add the two injector clips and resistor box. Thats the only way that i've ever been told how to do it. Look at my post in the FS/WTB thread... i have all the parts that you need to do this part of your project.
Old Jun 9, 2007 | 11:28 AM
totoshatch's Avatar
what all do you have? how much do you want for it?
Old Jun 9, 2007 | 11:40 AM
totoshatch's Avatar
what is FS/WTB and how do i look at it? i know i sound dumb but its my second day here.
Old Jun 9, 2007 | 12:32 PM
EFHATCHMAN's Avatar
Ok dude, go to the main screen click on the "Official FS/WTB thread for CRX/Civic EF parts. then go to page 19 and youll find my post toward the bottom of the page. Thanks!
Modified by EFHATCHMAN at 2:32 PM 6/9/2007
jdeibert
Feb 1, 2011 02:44 PM
jdeibert
Jan 6, 2011 09:31 AM
totoshatch
Jun 11, 2007 04:03 AM
RobbieG35
11
Aug 9, 2004 08:51 AM
boosh
Jun 24, 2003 07:45 AM
