thermostat replaced overheat still
Old Jun 8, 2007 | 01:37 PM
TheTealHatch's Avatar
Default thermostat replaced overheat still
I just recently replaced my thermostat and put in new coolant but my car still overheats in about 30 minutes. I need to figure out what it is cause its summer now and it gets hot even faster.
Old Jun 8, 2007 | 02:25 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: thermostat replaced overheat still (TheTealHatch)
is the fan working?...you get all the air out? it could be a few things
Old Jun 8, 2007 | 02:36 PM
Default Re: thermostat replaced overheat still (Throwdown)
Yeah i did.
Old Jun 8, 2007 | 02:46 PM
Throwdown's Avatar
and its not leaking have you pressure checked it? whats your rad cap look like? more info please
Old Jun 8, 2007 | 08:05 PM
i checked the pressure on all the hoses and they all have pressure on them. what do you mean by how does the rad cap look like?
Old Jun 8, 2007 | 08:09 PM
Could it be a bad head gasket? the hoses are a bit over warm, but it can get very hot.
Old Jun 8, 2007 | 08:13 PM
95DxSi-R2
Guest
Posts: n/a
how does it know
Old Jun 8, 2007 | 09:29 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Does the fan come on when it starts over heating? Check your lower hose, and make sure it isn't collapsed. My EF had a collapsed lower radiator hose and i had to drive it home from a 900 mile road trip in the sweltering summer WITH THE HEAT ON THE WHOLE WAY. It started raining at one point too. God that sucked.
Old Jun 8, 2007 | 09:46 PM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Default Re: thermostat replaced overheat still (B serious)
you may have a coolant blockage, if your coolant is dirty flush the whole system and replace with fresh coolant
Old Jun 8, 2007 | 09:49 PM
HiProfile's Avatar
Default Re: thermostat replaced overheat still (Rayz_Si)
Radiator can be cloged by using tap water (mineral deposites), air in the lines (keeps t-stat from opening by staying cool), bad pump, or a bad headgasket. There's ways to test for them all, just look around. Likely its air and maybe your waterpump. My bro just did his waterpump, looked ok when removed, but the new pump fixed his 20-minutes-per-overheat problem.
Old Jun 9, 2007 | 12:15 AM
Default Re: thermostat replaced overheat still (HiProfile)
i flushed out the old coolant already and i checked for any bubbles in the coolant. so im guessing i have to check the waterpump. also the fan doesnt come on at all even when i let it sit and turn on the heater full blast.
Old Jun 9, 2007 | 12:19 AM
shouldnt a water pump only be replaced if its leaking??(thats what ive read so far) so i narrow it down to the head gasket then?
Old Jun 9, 2007 | 02:08 PM
methos713's Avatar
I am having the same issues. I'm thinking its either the head gasket, water pump, or warped head....drove it around once around town stuck in traffic with the needle near H.
Old Jun 9, 2007 | 03:12 PM
ITLNstallion818's Avatar
Default Re: thermostat replaced overheat still (methos713)
sounds to me like a bad headgasket... have a friend drive around behind you and see if you burn white smoke, if you do... you're burning coolant and have a bad headgasket... or water pump
Old Jun 9, 2007 | 05:05 PM
Default Re: thermostat replaced overheat still (ITLNstallion818)
i think its burning white smoke cause i down shifter and my girlfriend behind me said there was white smoke. I just figured my fan does turn on when my needle is on completely hot. When i push my car for a few seconds the temperature shoots all the way hot.then a few mins after i have my car still but on it slowly cools down but is still pass the half way mark. Also after it heats up the car starts to lag when i try to go. it laggs around 2 grand...Is it cause of the over heat? or something else
Old Jun 9, 2007 | 06:50 PM
dtapia's Avatar
ok sounds like a very simple problem here. first i presume you check the fuse for the cooling fan ? and the cooling fan relay ? does the fan motor work if powered by a 12 volt source ? also what year car is it more info is needed.
Old Jun 9, 2007 | 09:05 PM
Default Re: thermostat replaced overheat still (dtapia)
cheked the fuse for the cooling fan already and it was good. its a 94 cx with a d16z6. the fan comes on but it takes forever for it to come on.
Old Jun 10, 2007 | 12:59 AM
methos713's Avatar
do you have to refill you coolent constantly? I have to for mine. It heats up when ride'n and the fan doesn't do much, but when I pop the hood and look at the res. tank...I can see coolent coming out of the cap. Open it and steam comes out. I let it cool off for awhile...go check...and no coolent in the res. tank.
Old Jun 10, 2007 | 06:23 AM
I dont refill it constantly, but my res tank is pretty filled up. It doesnt over flow.
Old Jun 10, 2007 | 06:31 AM
Targa250R's Avatar
be professional
What engine is this? I have a sneaky suspicion that it is a D15B7 with a bad head gasket, but need some more information.
Your fan should turn on before the temp needle even moves from its normal position. Test your fan switch.
If the needle makes it all the way to H, you're already doing damage. Do not drive the car when it is hot.
Old Jun 10, 2007 | 07:16 AM
erixxxhouse's Avatar
Sounds like its the D15b7 for sure. If it is then I can guarantee that the engine is corroded in the cooling channels. Mine was so bad I was surprised it ran for as long as it did.
Time for a swap
Old Jun 10, 2007 | 01:00 PM
Default Re: (erixxxhouse)
its a d16z6. How do i test the fan switch?? Im guessing something is wrong with the sensor cause it takes too long for the fan to even come on.
Old Jun 11, 2007 | 08:42 PM
Default Re: (TheTealHatch)
Are all fan switchs the same??
Old Jun 11, 2007 | 08:48 PM
95ProjectEJ1's Avatar
You can get aftermarket switches and thermostats that operate at a lower temp like a spoon thermo and switch for example.
Old Jun 11, 2007 | 09:50 PM
Default Re: (95ProjectEJ1)
Any links where you can lead to me good prices for those?
