Just making sure I did my B18C swap correct!
Old Jun 8, 2007 | 01:24 PM
ej2civic's Avatar
Default Just making sure I did my JDM B18C-R swap correct!
Car is EG9. So it has stock B16A2.
-Changed B16A2 injectors to JDM B18C-R
-Used OBD1 distributor
-Added knock sensor to harness
-Used boomslang OBD1 -> OBD2 conversion, so that I can use that JDM B18C-R ECU
Idle is just little over 1000rpm and stays steady?!
Is there something im missing?!
Thanks
Modified by ej2civic at 2:49 PM 6/8/2007
Old Jun 8, 2007 | 01:50 PM
ej2civic's Avatar
Default Re: Just making sure I did my JDM B18C-R swap correct! (ej2civic)
bump.
Give me little help here
Relic1's Avatar
the injectors are the same
you're running a stock P30 ECU?
1000RPM idle when cold or at all times?
Old Jun 8, 2007 | 03:10 PM
sauceja's Avatar
Default Re: (Relic1)
Should be a P73 ecu if JDM B18C-R ECU
Old Jun 8, 2007 | 11:51 PM
ej2civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">the injectors are the same
1000RPM idle when cold or at all times?</TD></TR></TABLE>
No Im running the ECU that came with the whole car. Everything is swapped from JDM DC2
1000rpm idle when warm and doesn't drop.
ej2civic's Avatar
Default Re: (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">Should be a P73 ecu if JDM B18C-R ECU</TD></TR></TABLE>
Yep should be that since it is taken from that -97 JDM DC2...
Old Jun 8, 2007 | 11:54 PM
tealj1's Avatar
Default Re: (ej2civic)
check your vacuum lines or try adjusting your tb screw.
Old Jun 9, 2007 | 01:35 AM
zero-one's Avatar
yup vacum lines
Old Jun 10, 2007 | 06:23 AM
ej2civic's Avatar
Default Re: (zero-one)
all vacuum lines are tight
And idle screw is screwed down to bottom
Modified by ej2civic at 7:17 AM 6/11/2007
Old Jun 10, 2007 | 06:48 AM
instrument's Avatar
why did you buy a conversion harness, i would've just gotten the ob1 ecu.
and why did you change injectors? from what you're saying the b18c had b16 injectors? ?
this swap is completely plug and play, all you had to do was the the obd1 ecu and not change anything at all.
have you checked your throttle cable to make sure it's pulling at all?
Old Jun 11, 2007 | 06:26 AM
ej2civic's Avatar
Default Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">why did you buy a conversion harness, i would've just gotten the ob1 ecu.
Well why would I buy OBD1 ecu for it? Everything is taken from FULLY WORKING JDM Integra TypeR?! So it had OBD2 ECU..
Why I change injectors? Well, you know that RHD harness doesn't bolt-on LHD car? Anyways B18C-R harness injector connectors are different than B16A2 harness has...
No throttle cable is not pulling...
Old Jun 11, 2007 | 06:36 AM
mike1114's Avatar
To adjust idle properly I believe you need to disconnect your IACV and then adjust the idle screw on the throttle body.
Check the service manual and follow the procedure to set the idle.........should be more around 750ish.
joel.j.tellez
15
Dec 9, 2013 09:35 AM
DJ 2501
20
Jun 28, 2013 07:11 PM
hondaej2nr
13
Apr 21, 2007 03:34 PM
SPiFF
11
Sep 2, 2005 05:32 PM
Lude S
Jul 11, 2005 08:08 PM
