Stupid plastic connectors
Old Jun 4, 2002 | 11:41 AM
99civic_exSB's Avatar
Default Stupid plastic connectors
OK Here's a dumb question for you...how do you get those little connectors off that hold the splash guards on in the fenders/wheel wells? These connectors are flat and it looks like you can put a screwdriver on either side and pop it out but it doesn't work. Sorry for the dumb question...
Old Jun 4, 2002 | 12:20 PM
Jaminak's Avatar
Default Re: Stupid plastic connectors (99civic_exSB)
It's just as you said - you put a screw driver on either side and pop out the center. They are 2 pieces - The middle piece is what you will pry out. If for whatever reason that wont work for you the middle piece can be drilled out. The clip will just fall out then. HTH
-Jamin
Old Jun 4, 2002 | 12:48 PM
JeffS's Avatar
That's exactly what you do. I usually end up breaking about half mine when I try it though and have to replace them.
Old Jun 4, 2002 | 01:02 PM
M-EJ1's Avatar
actually... in my 95 coupe, those little plastic things that hold the fender well splash guard in have a plastic phillips head screw in them that puts pressure on the whole assembly when you tighten it, so it stays in place. Get a small flathead screwdriver or a thin blade of some sort, and a phillips screwdriver. put the flathead screwdriver or blade under the screw and put some pressure on it, then unscrew it with the phillips screwdriver. After that, you should be able to pull the piece out without tearing your splash guard or working yourself into a cursing storm when you can't pull it off
[Modified by matt-eg, 10:02 PM 6/4/2002]
Old Jun 4, 2002 | 04:12 PM
Default Re: Stupid plastic connectors (matt-eg)
I'll give that a try. I've usually ended up breaking them or just drilling them out cause they're such a pain. The pressure idea sounds good. Thanks guys.
Old Jun 4, 2002 | 07:24 PM
JeffS's Avatar
bah... I'm always getting cars mixed up. The prelude didn't have screwheads in some places. The ones with the phillips-head are a lot easier to get out.
Old Jun 5, 2002 | 06:46 AM
Jaminak's Avatar
Default Re: Stupid plastic connectors (JeffS)
Yeah, but if you have a 99 then they are the pop out kind to take the fender liner off.
JFYI - the side skirts have those plastic screw in the middle kind.
crxaddikt
Jul 11, 2014 02:04 PM
Pauly321
Jul 30, 2009 05:41 PM
Rhythm Racer
Jul 6, 2003 11:53 PM
ih8danoles
Apr 21, 2003 12:21 PM
Isaac
Sep 9, 2001 05:28 AM
