Symptoms of a failing ignitor???
Old Jun 4, 2002 | 11:19 AM
dragnGSR's Avatar
Default Symptoms of a failing ignitor???
I was wondering what the symptoms of a failing ignitor would be? If I'm cruising on the interstate at a constant speed, the car has little hiccups. I think I've narrowed it down to the ignitor. I just replaced the distributor cap, rotor, plugs, and wires.
Also, where could I purchase an ignitor?
Old Jun 4, 2002 | 05:39 PM
dragnGSR's Avatar
Default Re: Symptoms of a failing ignitor??? (dragnGSR)
Anybody???
Old Jun 4, 2002 | 06:30 PM
kidkutz's Avatar
- tachometer reading jumps
- car won't start right after turning it off
Old Jun 4, 2002 | 07:52 PM
paulzy's Avatar
I get those hiccups too...I'm thinking mine is fuel related...I did buy the car like that with a code 7(TPS)though...if you find out, let me know
Old Jun 4, 2002 | 08:08 PM
Ri5e's Avatar
Default Re: Symptoms of a failing ignitor??? (Slow_ass_4dr)
Definetly Tach, RPMs just jump around. Then the car shuts off.
$220 I believe for the Igniter, ouch!
earl's Avatar
Not positive on your set-up, but in most cases the ignitor gets too hot and shuts down the engine completely. Engine will start after it cools down. Ultimately it just fails completely and you have no spark. I'd look for a short somewhere assuming your not getting a CEL.
Old Jun 4, 2002 | 08:11 PM
dragnGSR's Avatar
Default Re: Symptoms of a failing ignitor??? (kidkutz)
Nope, no CEL. But on the other hand, I am having the exact same syptoms that kidkutz is describing. At idle, my idle is not steady...it bounces up and and down but not erractically. Also the car won't start right after turning it off. OMG, $200+ for a new ignitor! That's gonna suck.
Old Jun 4, 2002 | 08:56 PM
kidkutz's Avatar
i paid $100 CDN for my ingitor...that's like $60 USD!
Old Jun 4, 2002 | 10:36 PM
Dutchie's Avatar
$100.00? I was just quoted $275 for one from Acura. I guess the Prelude ones are a lot cheaper.
Old Jun 5, 2002 | 03:21 AM
EE_Chris's Avatar
But beware, if your ignitor is failing, it could also be a symptom of a failing coil. Only sure way to know is to scope it out using an amp meter (clamp variety).
Old Mar 6, 2015 | 09:58 AM
Marcusj's Avatar
So my 91 accord turns over and everything but won't start so would it be the ignitor I changed cap and rotor still no spark
Old Mar 7, 2015 | 01:57 PM
wantboost's Avatar
Who is Mr Robot?
This is a 13 YEAR OLD THREAD!
start a new one
Old Mar 7, 2015 | 08:34 PM
MOE@Hyper16Valve's Avatar
Icon6 Re: Symptoms of a failing ignitor???
i fixed my problem the plug it self the pin connectors where loose i could touch the connector and the idle would jump or cut the car off .
My fix i got out the pick tool and push down the clips to make better contact trust i bought a NEW ACCEL 11076 coil tried a working ignitor same bought a NEW ignitor same so one day is moving the harness and VIOLA i find the loose ness in the TPS singal , Trust it did'nt do it ALL the time RIGHT thats whats happening probally with some of you guys.
check the pin connectors if you KNOW your parts that you replaced ARE in Fact NEW.
MY 2cents.
dsnONE
15
Apr 27, 2012 05:39 PM
R5Kxxwhatxx10
12
Sep 23, 2009 02:11 PM
DBAl
May 7, 2009 06:47 PM
lilshady6796
Nov 12, 2008 09:02 AM
sohcVTEK
Jun 18, 2006 08:44 PM
