help with front door window trim
the black material covering the trim started to peel away so i decided to blade everthing off. everything did not come off as clean as i wanted. should i sand with 1500 grit and then polish or what? if i do sand it then should i use 3m rubbing compound or mothers aluminum polish? it'd be easier if i knew how to take it off. i tried pulling at it in every direction but it didn't budge.
here are some pics:
looks good from a distance. i would rather replace it than cut the others. plus, i figured that the weatherstripping was there for a reason.
Modified by oem_CD5 at 9:00 PM 6/7/2007
here are some pics:
i would tape off the surrounding area and then wetsand it with 600 grit followed by 1500 grit. then i would polish it with metal polish. then wax to protect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WihaSi »</TD></TR><TR><TD CLASS="quote">What window trim are you talking about? Belt strips (belt weatherstrips, belt moldings)? </TD></TR></TABLE>
the one in the picture, the one that peels on almost every 90's honda.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CD7 »</TD></TR><TR><TD CLASS="quote">Is your Accord a LX or DX?
I've been trying to find the window trimming in black for years.</TD></TR></TABLE>
it's a dx.
so no one knows how to take it off? i don't think i want to do the other three window trims. it's a dilemna because a new one would cost around $60 from tasauto.com i think.
http://www.secureleadercom.com...block
it's either that or do the other three . . .
it's a dx.
Unjockable
15
Nov 4, 2002 08:54 PM
