CRX with b18a1 won't crank, just beeps after weird hot starting problem
Old Jun 7, 2007 | 04:06 PM
timarbeau's Avatar
Default CRX with b18a1 won't crank, just beeps after weird hot starting problem
i used to have a wierd starting problem: only when the engine was hot, sometimes if i turned it off, it would crank but not start, hitting the gas had no effect. if i hit the pedal a couple of times and let it sit for a minute, it would start right up... ???
the genius that put my engine in ghetto-rigged all the sensor plugs, etc. into the old crx wiring... it worked great, but sometimes the power was a little inconsistant. i discovered that my oil temperature sensor was unplugged, and didn't even have a plug for it, so i got a plug off an integra and connected it to the 2 wires of matching color where they went into the ecu.
now it won't crank or anything, it just makes a slow, quiet beep, beep... i disconnected my new sensor plug, and that doesn't make any difference, the fuses under the hood are all good, and there's plenty of voltage in the battery.
Any ideas?
Jeremy Harris
21
May 2, 2016 10:58 AM
Thategguy94
Feb 7, 2015 01:15 PM
turnsignalandy
Nov 10, 2012 04:56 AM
w3bcod3r
May 31, 2007 03:12 PM
420aNT
May 18, 2003 04:22 PM
