Vitara piston to wall clearance
The machine shop told me my piston to wall clearance as of now is already .005" and recommends me to go with oversize pistons but thats not an option for me right now. OEM service limit is only .002". Is this going to be ok and will there be any problems down the road? I don't know what the recommend clearance for vitara pistons are, but if any has gone thru a similiar situation can chime in? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockb18c »</TD></TR><TR><TD CLASS="quote">might here some slap</TD></TR></TABLE>
Yeah he said I'll have some slap during cold start..
there is plenty of debate on this subject going on around td16.com
http://turbod16.com/viewtopic.php?t=34073
^ this thread is about a guy who has a .008 piston to wall clearance
read these through. it might help clear up questionss
ANOTHER
http://www.turbod16.com/viewtopic.php?t=31192
read these through. it might help clear up questionssANOTHER
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucioussae »</TD></TR><TR><TD CLASS="quote">there is plenty of debate on this subject going on around td16.com
ANOTHER
http://www.turbod16.com/viewtopic.php?t=31192</TD></TR></TABLE>
Thanks
Thanks
youll be fine, i ran .004 on mine and it slapped a tiny bit...i have heard worse on forged piston cars. and yes jfk_78 runs .008 on his car and puts out the most of anyone using vitaras...thats gotta speak for something
fjt said I can exchange for some 76mm, but will that be fine on stock sleeve? or should I just stick with the 75mm and hopefully have pwc at around .0055"- .006" after a slight hone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ehtwo »</TD></TR><TR><TD CLASS="quote">fjt said I can exchange for some 76mm, but will that be fine on stock sleeve? or should I just stick with the 75mm and hopefully have pwc at around .0055"- .006" after a slight hone? </TD></TR></TABLE>
yes, you will need to bore/hone though... then again, jfk ran on .008 without any problems..
from what i hear, .004 is best on these suckers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litovi3tboi503 »</TD></TR><TR><TD CLASS="quote">Go with .01" clearance you will be golden!
I hope you are kidding.
</TD></TR></TABLE>I hope you are kidding.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast2camciv »</TD></TR><TR><TD CLASS="quote">youll be fine, i ran .004 on mine and it slapped a tiny bit...i have heard worse on forged piston cars. and yes jfk_78 runs .008 on his car and puts out the most of anyone using vitaras...thats gotta speak for something
Your car was my inspiration
</TD></TR></TABLE>Your car was my inspiration
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">
I hope you are kidding.</TD></TR></TABLE>
why would i be kidding
becauase .01" is TEN THOUSANDTHS of an inch... most forged pistons install anywhere from .0045-.0055 and higher depending upon how much heat you're going to put into the piston (expand via Horsepower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .R T E r n i e »</TD></TR><TR><TD CLASS="quote">becauase .01" is TEN THOUSANDTHS of an inch... most forged pistons install anywhere from .0045-.0055 and higher depending upon how much heat you're going to put into the piston (expand via Horsepower) </TD></TR></TABLE>
.01" is a HUNDREDTH ( .1 tenth, .01 hundredth, .001 thousandth, .0001 ten thousandth)
....you are right though! .01 is WAYY to big of a gap to be running, OP will be lucky if his car goes anywhere and has oil by the end of the week if he dares put this in his car.
....you are right though! .01 is WAYY to big of a gap to be running, OP will be lucky if his car goes anywhere and has oil by the end of the week if he dares put this in his car. </TD></TR></TABLE>
<FONT SIZE="4"><FONT COLOR="red">YEAH NO ****...
ONE HUNDREDTH= 10 THOUSANDTHS</FONT></FONT>
why would i be kidding</TD></TR></TABLE>
Ignore him he's just messing around.
Chill, homeslice. Simple math eludes some people. Further, their inability to measure in the commonly accepted units any automotive machinist is conversant with shows how little they know. Arguing on the internets with them will not change this.
Finding their home address, and killing them before they can breed, will make the world a better place, though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis »</TD></TR><TR><TD CLASS="quote">
ha...for some reason I felt compelled to break out the bolt, size=4, and the almighty color=red.
Mine had .006 clearance and it ran fine for the 2 yrs i had it. Never had problems of blow by and always my Compression test numbers were even.
JFK's car has .008 clearance and he holds the record for most hp out of the vitaras and stock sleeves (443whp)
BTW: I should be receiving 75.5mm vitaras in around a week or two and a second batch by mid July.
i just built another block for someone, it had .0045 clearance...customer says it runs like a champ...i also over saw the build of another block that runs .006 and it is running flawless as well....on the 2nd motor it really has no audible slap at all...not sure why, but its very quite.
thanks
good luck with yours!!
</TD></TR></TABLE>thanks
AaronJ
May 1, 2008 05:42 PM
.adam.
Nov 21, 2007 02:39 PM
dude_123
Sep 29, 2005 08:02 AM
