rear cam plug question ??
have anyone done a rear cam plug replacement on a gsr ?
is it simple what would i have to do to replace it.
is there any step i can follow ?
any info would help thanks,
it's a pretty straightforward thing.
1. Remove coil
2. Remove the VC
3. Remove the 4 bolts that hold the cap on
4. Remove the cam cap.
5. Replace/clean out and put in some high temp engine sealant.
And here's a write-up for an H series, but it is similar.
https://honda-tech.com/zerothread?id=1778520
1. Remove coil
2. Remove the VC
