gsr engine
Old Jun 7, 2007 | 02:06 PM
RoB316's Avatar
Default gsr engine
i just rebuilt my gsr and bought new valves, springs, retainers, and i also bought buddy club stage 5 cams. anyone have experience with these??? i start it up and it sounds like the engine skips a little and when you hold the throttle open from 1000 rpm to 4000 rpm and i was wondering if i need to get bigger fuel injectors and a chipped ecu???
Old Jun 7, 2007 | 02:13 PM
dohcMONSTER's Avatar
Default Re: gsr engine (RoB316)
so you just put all of that in your motor? what are you using to tune? what motor? USDM or JDM? stock block? what else is done to your car? ...... help us help you
Old Jun 7, 2007 | 02:20 PM
RoB316's Avatar
Default Re: gsr engine (dohcMONSTER)
its a usdm b18c1 with the following mods...
new valves, springs, and retainers
head was sand blasted and cleaned
stock block that was honed and cleaned
new itr pistons
new rings
everygasket and seal was replaced
new greddy headers
new evo 2 exhaust
act stage 2 clutch
new fidanza 12 lbs flywheel
stock ecu, fuel injectors, and fuel rail
thats about it
Old Jun 7, 2007 | 02:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoB316 &raquo;</TD></TR><TR><TD CLASS="quote">
thats about it
thats your problem, your ecu is running a stock base map on a car FAR from it
Old Jun 7, 2007 | 02:33 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
^^^ thread/
Old Jun 7, 2007 | 02:37 PM
RoB316's Avatar
Default Re: (jdm_dc_fan)
so should i get a new rail, fuel injectors, and ecu?? if so, what would you guys recommend?? plus, i have a vafc2, would this work for tuning???
Old Jun 7, 2007 | 03:37 PM
slow_ls's Avatar
Just get it tuned! A fuel rail would be a waste of money and i'd say your stock injectors are probably big enough. If your obdII get a conversion harness and an obdI ecu and have that chipped for whatever you decide to use I.E. hondata, uberdata, chrome etc. than take it to a tuner and problem solved.
Old Jun 7, 2007 | 04:27 PM
Default Re: (slow_ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_ls &raquo;</TD></TR><TR><TD CLASS="quote">Just get it tuned! A fuel rail would be a waste of money and i'd say your stock injectors are probably big enough. </TD></TR></TABLE>
No, at least get bigger injectors. Anything over 80% duty cycle will become inconsistent and stock injectors usually hit 100% cycle at around 200whp which your set-up should be good for. Its always better to go bigger and then get it tuned down then to max out stock injectors.
Old Jun 7, 2007 | 04:43 PM
doood's Avatar
been there done that
Default Re: (dohcMONSTER)
wow, bc5's? those are some huge cams. they're gonna want at least 12.5:1 and a better breathing system than that to see their full potential.
Old Jun 7, 2007 | 05:37 PM
RoB316's Avatar
what size injectors should i get for this setup???
Old Jun 7, 2007 | 05:42 PM
doood's Avatar
310-370cc
Old Jun 7, 2007 | 05:49 PM
RoB316's Avatar
Default Re: gsr engine (doood)
so bigger injectors and a good tune will make this setup run pretty smooth?? also, i have an obd2 ecu, will this be a problem???
Old Jun 7, 2007 | 05:53 PM
doood's Avatar
you need to convert to obd1 if you want to use a chipped ecu. or spend the big bucks for an aem or other standalone.
a vafc or other piggy back just wont cut it. may i ask why you bought such big cams for such a mild setup?
Old Jun 7, 2007 | 05:58 PM
sauceja's Avatar
Unless you know someone that made a miracle discovery on how to tune and obdII car.
OBD2x-OBD1 harness and a chipped OBD1 ECU are your first two needs.
Like said ^ cams are a little aggressive. Did you degree them?
You should have used at least P30's and flat faced valves. But I am not here to bash your setup.
Fuel rail is not needed. I got one only because my ITR IM needed something besides a B16 rail so I just got the Golden eagle rail.
For 100.00 get a walbro 255 lph pump.
If you are going to buy injectors just get 370's and be done with it. Don't buy 310's and barely have enough.
Thats all I got right now.
Old Jun 7, 2007 | 07:14 PM
saver's Avatar
my i ask how much you spend to get your head and block done? and did you get it fully rebuilt to stock mode? and if anyone know if thats a good way to really start a fresh milage. im sorry not meaning to steal your thread. i just need to rebuilt my gsr to much milage and burning to much oil.
Old Jun 7, 2007 | 07:39 PM
sauceja's Avatar
Default Re: gsr engine (saver)
DonF is pretty darn good from what I hear.
There are lots of guys.
Old Jun 8, 2007 | 06:34 PM
RoB316's Avatar
Default Re: gsr engine (sauceja)
do you guys think i can put the stock cams back in and it would run good just to get it to the tuner??
Old Jun 8, 2007 | 07:18 PM
96teggylsse's Avatar
yea that would work too... i guess... if you wanna do that
Old Jun 8, 2007 | 07:41 PM
sauceja's Avatar
Default Re: gsr engine (96teggylsse)
Actually sounds like your spark plugs are out of gap or shot.
Old Jun 9, 2007 | 12:43 PM
deegz's Avatar
x2, \
and sounds like lift duration is to big for your setup...
Old Jun 9, 2007 | 12:47 PM
sPaRk'iT's Avatar
Default Re: gsr engine (deegz)
Stage 5 cams with stock ecu and no tuning
Old Jun 9, 2007 | 01:10 PM
SleeperGSR's Avatar
Default Re: gsr engine (sPaRk'iT)
Your problem is definatly your cams. You totaly have the wrong one. Stage 5 is only for a race prepaired motor that gets rebuilt monthly, and you don't have that. I would get skunk 2 stage 1 or 2 at most for a daily driver rebuild. good luck
Old Jun 9, 2007 | 01:54 PM
unrivaledintegra's Avatar
i got a good site u can go to if u still need an e.c.u phearable.net he has done my whole crews e.c.u's and he dose it quick
Old Jun 9, 2007 | 01:58 PM
SleeperGSR's Avatar
Default Re: gsr engine (unrivaledintegra)
Even if this dude gets his ecu flashed it's not going to run right. The cams are way to aggressive for the application.
Old Jun 9, 2007 | 02:08 PM
Micha's Avatar
FAILWGN
Default Re: gsr engine (SleeperGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">Even if this dude gets his ecu flashed it's not going to run right. The cams are way to aggressive for the application. </TD></TR></TABLE>
I fifth this comment.
