Extended stud and bearing question
Old Jun 7, 2007 | 11:35 AM
Skeletor's Avatar
Default Extended stud and bearing question
I recently bought an ITR suspension for my Civic and I'd like to put in extended lugs. Should I replace the bearings as well since the mileage is unknown? What are the part numbers for the front and rear bearings? I figure I should do it when I put it on since everything will be apart anyway.
Old Jun 7, 2007 | 11:41 AM
GUILOTINE's Avatar
Kill Gil
Default Re: Extended stud and bearing question (Skeletor)
Just replace the front bearings. They use the same bearing as all other 94-01 integras
Old Jun 7, 2007 | 11:58 AM
Ed 341's Avatar
Are the bearings bad?
Old Jun 7, 2007 | 12:04 PM
Skeletor's Avatar
I'm not sure yet. Is there any way to tell with the suspension off the car?
KOALA YUMMIES's Avatar
Default Re: Extended stud and bearing question (Ed 341)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 &raquo;</TD></TR><TR><TD CLASS="quote">Are the bearings bad?</TD></TR></TABLE>
I wouldnt risk even asking, they could have 200,000 miles on them and go bad in a month...
The question I'd ask first is: is the 5-lug legit?
Old Jun 7, 2007 | 12:14 PM
Skeletor's Avatar
I certainly hope so. I bought it from a business on here and I've had it for over a year. It's JDM I think. Should I replace all bearings? What are the part numbers?
Old Jun 7, 2007 | 01:33 PM
94rs-turbo's Avatar
reat studs can be installed w/o removing the bearings, you might have to unbolt the hub assem. though fronts will need to be pressed out and replaced with new hub bearings
Old Jun 9, 2007 | 06:15 AM
Skeletor's Avatar
So I should just replace the fronts? Are the ITR bearings the same as all the Integras?
TurboKneeGrow
13
Feb 29, 2008 03:40 AM
ge_itr
Feb 1, 2007 08:12 AM
pumpkyn
Oct 6, 2006 02:26 PM
domestic abuser
Jun 18, 2006 08:33 AM
marcussmith26
Jan 28, 2006 01:45 PM
