Ingalls or SPC adjustable ball joint?
Old Jun 7, 2007 | 11:23 AM
manbearpig's Avatar
Default Ingalls or SPC adjustable ball joint?
My upper ball joint went bad recently, now I'm looking to replace it and my cheapest options are either going to be the spc or Ingalls adjustable upper ball joint, as opposed to the whole uca. I've read that most guys with ludes go with the spc but I just wanted some advice before I purchased them. Thanks for the help guys.
Old Jun 8, 2007 | 07:13 PM
manbearpig's Avatar
Old Jun 9, 2007 | 07:25 AM
NirVTEC's Avatar
Default Re: (mang.)
Do you race? If not OEM!
Old Jun 9, 2007 | 08:05 AM
manbearpig's Avatar
Default Re: (:=:NirVTEC:=:)
No, I dont race, but I was looking for a cheaper route than the entire uca's. Plus, If I wanted to lower my car in the future.... which I do, I wanted to be able to adjust camber If I go that low.
Old Jun 9, 2007 | 10:00 AM
NirVTEC's Avatar
Default Re: (mang.)
Honestly if youre going low enough to need camber control youre too low....
I just replaced the whole UCA last year......you can get them for near cost from Majestic.
I guess you have to price what 2 adjustable's would cost VS 1 OEM.
Old Jun 9, 2007 | 10:45 AM
m00nr0ck Si's Avatar
Default Re: (mang.)
I had the SPC's on my EJ1 civic and they were great....Easy to install and fully adjustable from -4 to +4 degrees...
Old Jun 9, 2007 | 02:39 PM
Apex1972's Avatar
Default Re: (dorkoftheyear)
if you are vert low, (2.5 inch drop) or more, you probably do need these.However, if you are this low,you will probably have a clearance issue with the adjustables(SPC). I have these on my 92 Si. I have Skunk2 drop springs. Not coilovers. I have AGX skocks. I had to cut the area that is located above the 22mm nuts that are on top of the SPC ball joints. After making the needed clearance, my car rides 1000 times better. If you look on the pass.side near the fuse box, you will see 3 holes very small. They are pretty much the template for the hole that is needed. I realize this mod is not for the weak, but it really helped my car because the nuts were making contact with the unibody area. I agree though, the SPCs are a better alternative to the upper control arms.Hope this helps.
Old Jun 10, 2007 | 08:07 AM
manbearpig's Avatar
Default Re: (Apex1972)
I'm probably just going to go with one adjustable now, and replace the other down the road when I get the chance/money for it. I have a parts car so my car wont be out of order very long, I can just take the uca's off of it and do everything on a bench that way when I go to change them on my car it will be a breeze. Thanks guys
Old Jun 10, 2007 | 08:35 AM
prelude_h22vtec's Avatar
i've got a set of the SPC's i never installed. you can have them cheap
Old Jun 10, 2007 | 11:59 AM
93sivtec's Avatar
Default Re: (prelude_h22vtec)
I have the ingals,and they are great,very hardy and never slipped in a year and a half.I also have some knock off ingals in the rear,but not the upper ball joint type like the front,but the cheap bolt kind,they slip all the time,it got to the point where I used loc tite on them to finally get them to hold.
I have heard good things about both,and have good experience with 1 first hand,but if ^^^^^^^^^ dude will sell them cheap,I would just get those spc's.
Old Jun 10, 2007 | 06:26 PM
manbearpig's Avatar
Default Re: (93sivtec)
already on it
DK SkeeS_EF
15
May 24, 2012 05:10 AM
boostedb20z
Suspension & Brakes
23
Aug 25, 2011 07:30 AM
scorpion-stinger
Apr 17, 2009 09:59 AM
AdReNaLiN
Oct 17, 2008 12:00 AM
Sic_DA_Nine
May 30, 2008 09:11 PM
