will airbag deploy if i remove srs comp?
i dont have a passanger side airbag, but i do have a drivers side. if i remove the srs computer will the driver side bag deploy?
if not where is the srs computer located
as long as you arn't staticly charged when unpluging the connectors, then no it will not deploy.
but just remember if anything shorts to your now empty airbag plug, you have a nice explosion in your face.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b0l0 »</TD></TR><TR><TD CLASS="quote">
if not where is the srs computer located</TD></TR></TABLE>
Disconnect the battery and you won't really have to worry about it. The computer is located behind the radio (on a 4th gen anyway) and a tip that will help you is to remember that all SRS wires and connectors are yellow.
