skunk2 IM or JDM 4-1 headers???
oh ya...but if i get the header then ill have to get my piping and exhaust done and if i get the skunk2 intake manifold ill have to get a vtec controller to avoid the dip in power and also i will have to acquire a new type R aem cai.......help
Yup, you can still run your OEM exhaust with the JDM Header considering you have the right cat. Definitely get your basic bolt-ons before you get the Skunk2 IM, I would say even get better cams or you'll see a loss in power. If you haven't, work on your suspension first...at least I would.
im getting a typeR throttle body off my friends motor for 50 bucks...i think im pretty much done for suspension for now because i dont autoX...and for running the headers with the stock cat&piping it wont hurt nething right? thanks for the advice allmotor
El Veterano de Sur Califas
go with the header. It wont hurt anything if you have a stock exhaust, but you wont get the full potential of the headers. Also dont forget that you will need a donut gasket from a S2000(or one that will fit the 2.5" collector). But your next upgrade should be 2.5" piping, and a N1 exhaust(or something 2.5" in diameter).
manny
manny
don't forget if you get the IM, you have to get a new TB too and have it matched to the IM to maximize gains.
i would get the header first then work out all the bugs it takes to connect ur exhaust w/ the 2.5 collector. then upgrade ur cams, get vtec controller, ITR CAI, then get skunk2 mani.
Actually I would get the other exhaust cam
. But really, my choice would be a DC Sports JDM 4-1 header. It's identical to the JDM header, only with a 2.5 inch collector instead of 2.25.
Definitely header then skunk2 im itr aem cai and stuff...
Looks like your going all motor. After that if you want you can upgrade those ctr cams to Skunk2, Toda, Or Jun and valvetrains too. Good luck. Btw, lookin at your mods you definitely need gears.
andyfishy
May 18, 2017 08:54 AM
cr00klyn718
Jul 8, 2003 12:41 PM
