turbo charging an h22
Old Jun 7, 2007 | 10:48 AM
Raven_Accord's Avatar
Default turbo charging an h22
i have heard the the engine block of an h22 isn't strong enough to turbo charge but a f22 is. so i was wondering if it is better to just turbo my f22 or swap in an h22 with cams.
Old Jun 7, 2007 | 03:17 PM
Haccordclub's Avatar
Default Re: turbo charging an h22 (Raven_Accord)
its whether you want the pull from the dohc vtec or boost. personally i love boost, just get your f series compression and leak down tested, if its strong, turbo it, if not than swap an h. It also all depends on money, and knowledge with turbos, swaps etc. Turboing a car isn't easy.
Old Jun 7, 2007 | 03:46 PM
Default Re: turbo charging an h22 (Haccordclub)
thx for the advice
Old Jun 7, 2007 | 10:39 PM
Hawkze_2.3's Avatar
Read the Prelude forum FAQs...there's too much to go into.
Old Jun 8, 2007 | 12:06 PM
notoriousB's Avatar
Default Re: turbo charging an h22 (Mr Wonderfull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">ringlands are the problem... boost the f if you dont want to sleeve th h so you can run forged pistons. either way tuning will make you or break you.</TD></TR></TABLE>
it's not the block it's the ringlands. any stock honda piston's weak link is the ringlands.
93 Eg Couper
May 20, 2009 11:51 PM
preludejones
Nov 27, 2007 02:23 PM
donm3ga
Feb 13, 2007 08:17 AM
gustavito1986
Sep 28, 2006 03:59 PM
hybrid_eg
Jun 11, 2002 04:26 PM
