How to tell is I have a ITR throttle body ??
Old Jun 7, 2007 | 10:19 AM
Daniel-sanB1's Avatar
Default How to tell is I have a ITR throttle body ??
I purchased a ITR intake manifold and a throttle body.
and I don't have a measuring tool.
the intake has a P73 stamp at the back.
but the TB was defiantly reattached to the intake, and the grease marks weren't the same(didn't match up)
so HOW can I tell by looking at it, if it's a B16 or B18c5 Tb ??
and is there a cosmetic difference between the 96-97 and 98-01 tb ??
thanks
Old Jun 7, 2007 | 10:33 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: How to tell is I have a ITR throttle body ?? (Daniel-sanB1)
1st generation b16 is 58mm
all other b-series throttle bodies are 60mm with type-r as an exception at 62mm
p73 is itr.
Old Jun 7, 2007 | 11:44 AM
crackerjacker006's Avatar
Default Re: How to tell is I have a ITR throttle body ?? (ek forever guy)
if you have or can get a hold of any other bseries tb (gsr, b16, ls), you can hold it up to the type r and you should be able to notice a slight difference in diameter. I think all bseries are 60mm other than the one ek forever speaks of and your itr should be 62mm
Old Jun 7, 2007 | 12:14 PM
Ek Forever y0!
Default Re: How to tell is I have a ITR throttle body ?? (crackerjacker006)
Or any ruler with mm on it.
Old Jun 7, 2007 | 02:23 PM
b20beast978's Avatar
a c5 tb should be 62mm opposed to the standard 60mm from a b series
Daniel-sanB1
Jun 7, 2007 01:21 PM
Daniel-sanB1
Jun 6, 2007 10:10 PM
bm3r
Sep 8, 2004 08:09 PM
turb
Jan 7, 2003 08:51 PM
