Is there a way to add miles to my odometer?
Old Jun 7, 2007 | 10:09 AM
thatasiankidtony's Avatar
Default Is there a way to add miles to my odometer?
I just bought a 99 Acura CL cluster with 111k miles on it, and my car currently has 170,xxx. Is there a way I can add miles to the odometer w/o driving another 60k.
Old Jun 7, 2007 | 10:13 AM
Stealthman80's Avatar
Default Re: Is there a way to add miles to my odometer? (thatasiankidtony)
is it analog? you would have to take it out connect a drill to it and spin it till its at the desired reading, if its digital I have no idea
Old Jun 7, 2007 | 10:14 AM
One Bad GeeSeeR's Avatar
i dont know if thats possible esp. if its a digital mileage. and dont know if it is illegal or not.
best way is go to dmv and get that cluster certified or something that it is less miles than the car.
Old Jun 7, 2007 | 12:42 PM
Default Re: Is there a way to add miles to my odometer? (Stealthman80)
Acutally it's analog.
Old Jun 7, 2007 | 02:19 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
If the odometer is analog, and not directly attached as part of the Printed Circuit Board (PCB), you may be able to swap out PCB and use the original odometer. I don't remember how the 99 cluster looks like.
But, looking at the diagram for a 99 Accord, it looks like the odometer (digital?)may be part of the Printed Circuit Board (PCB):
http://www.slhondaparts.com/br...=true
Could you take a picture of the clusters you have? Also, why are you swapping the clusters, speedometer doesn't work, etc.?
Old Jun 7, 2007 | 02:40 PM
raceACCORDingly's Avatar
its analog. you gotta turn the gears manually
Old Jun 7, 2007 | 03:40 PM
JDM_DC4_Fanatic's Avatar
Default Re: (raceACCORDingly)
If Ferris Bulers Day Off has taught us nothing else, we should of atleast learned that if you jack up a Ferrari and drive it in reverse, the miles dont roll back, keeping this in mind, you gotta drive it, I dont think you can crank it manually because I think theres supposed to be a safty tab in one of the drums to prevent someone from tampering with the ODO. Or, maybe thats only to stop you from rolling it backwards.
Old Jun 7, 2007 | 03:49 PM
-RedneckDave-'s Avatar
Working
We are not here to break the law and that is what this is.
Christian_Chand
12
Apr 15, 2014 11:18 PM
Dam itz Lou
12
Nov 9, 2009 10:17 AM
BrianFreels
Oct 26, 2008 10:30 AM
mxl36o
Mar 14, 2007 05:09 AM
markysparky
Feb 6, 2006 06:55 AM
