OEM pressure plate with a 6 puck disc
Old Jun 7, 2007 | 08:08 AM
1991civicsi's Avatar
Default OEM pressure plate with a 6 puck disc
Does anyone use a 6 puck (or similar) with a OEM pressure plate? Im snapping clutch cables, so the softer OEM Pressure Plate will cause less stress. I just dont know if Im defeating the purpose in my 200hp boosted single cam.
LMK
Old Jun 7, 2007 | 09:32 AM
Donkey85's Avatar
Default Re: OEM pressure plate with a 6 puck disc (1991civicsi)
that would be kind of pointless. i really doubt the stock pp will hold the grip and abuse of the 6 puck....... you need something with a high clamping force that engages a little harder
Old Jun 7, 2007 | 09:33 AM
Donkey85's Avatar
Default Re: OEM pressure plate with a 6 puck disc (Donkey85)
also what clutch cable are you runnin stock or what? also what motor and trans setup are you using?
Old Jun 7, 2007 | 10:16 AM
Single cam turbo t3 Si 5sp, aftermarket cable (gonna get OEM Honda) and COmp Clutch Stage 4.
Old Jun 7, 2007 | 10:38 AM
Donkey85's Avatar
i would try a stock oem cable and give that a try, i'm using my oem with stage one clutch on my b16 and have no problems, also make sure there is a hair of play on the clutch pedal. so dont adjust it to the poing where there is no tension on the cable
Old Jun 7, 2007 | 11:54 AM
Raptastik87's Avatar
I ran a 6 puck on a stock pressure plate and the pp didn't hold the abuse for long so no, i don't recommend it. I upgraded to act heavy duty pp and it works great
black0hatch
Jul 1, 2011 10:48 AM
Eighty-Nyne
Jul 20, 2009 07:51 AM
vinuneuro
Transmission & Drivetrain
Apr 16, 2009 05:43 AM
sonne7126
Dec 15, 2008 05:35 PM
genetsang
Jan 26, 2003 07:35 AM
