rpm gauge not working
everything on my cluster, but the rpm isn't working. i have a 2000 gsr w/ 1994 jdm gsr swap and everything is converted to obd1 along w/ jumper cable with chipped p28 ecu. can someone explain about the rpm gauge?
you need to extend a wire from your distributor to the right shock tower. If you look at the plug for the distributor, you will see a wire that doesn't have anything on the other side. I had the same problem when I put a 2000 gsr motor into my 94 del sol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">OBD1_Pg1
OBD1_Pg2
OBD2a_Pg1
OBD2a_Pg2
OBD2b_Pg1
OBD2b_Pg2
Have fun matching wire colors.
Some obd2 distributors are missing a wire. This wire is the solid blue tach signal, obd2b takes it's tach signal from the main ignitor wire farther down in the harness. On these distributors you can open them up and put a wire on the empty tab on the ignitor then run the wire out and you have a nine wire distributor.
OBD1_Pg2
OBD2a_Pg1
OBD2a_Pg2
OBD2b_Pg1
OBD2b_Pg2
</TD></TR></TABLE>Some obd2 distributors are missing a wire. This wire is the solid blue tach signal, obd2b takes it's tach signal from the main ignitor wire farther down in the harness. On these distributors you can open them up and put a wire on the empty tab on the ignitor then run the wire out and you have a nine wire distributor.
topshotta
10
Mar 31, 2016 07:55 AM
Richard Wolfe
Sep 11, 2013 03:44 AM
