need help with putting 99 si gauges in 98 civic
Old Jun 6, 2007 | 08:30 PM
sivik-si's Avatar
Default need help with putting 99 si gauges in 98 civic
k i bought 99 si gauges and the rpm the mph ,gas and all the little light like engin light and all those work but the temp and the gauge light wont work wanted to see if any one else has had the problem and if they can help
Old Jun 6, 2007 | 08:45 PM
Targa250R's Avatar
be professional
Default Re: need help with putting 99 si gauges in 98 civic (sivik-si)
Sounds like you have a faulty gauge unit. Did everything work prior to swapping clusters? Did you plug all the plugs in when installing?
You'll probably need to order a new temp/fuel combo gauge from Honda and swap it into the cluster. They are around $36 (part no. 78130-S01-L01).
Hopefully nothing else on the cluster is hosed.
Old Jun 6, 2007 | 09:00 PM
sivik-si's Avatar
Default Re: need help with putting 99 si gauges in 98 civic (Targa250R)
on the 99 si gauges it has a spot for a green plug and my 98 civic does not come with that so im thinking that might be the problem what do think
Old Jun 6, 2007 | 09:10 PM
Targa250R's Avatar
be professional
The green plug is for cruise control. Definitely not the problem.
Old Jun 6, 2007 | 09:15 PM
sivik-si's Avatar
is there any other problem u might know about becuse the dude i bought them from said they worked befor
Old Jun 6, 2007 | 09:26 PM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sivik-si &raquo;</TD></TR><TR><TD CLASS="quote">is there any other problem u might know about becuse the dude i bought them from said they worked befor</TD></TR></TABLE>
He must've lied.
As long as you matched the plugs up right and left the cruise control plug alone, you should be fine. Otherwise it's a wiring/cluster issue.
Old Jun 7, 2007 | 03:15 AM
Targa250R's Avatar
be professional
They should have worked right off the bat - plug and play.
Either he intentionally sold you a cluster with a bad temp/fuel gauge, or something happened to it during shipping/installation. The circuit sheet on the back isn't damaged in any way, is it? Was it packed well for shipping?
1freshEM1
Jan 10, 2010 10:17 AM
sivik-si
Jul 4, 2007 09:34 AM
grncivic98
Apr 12, 2005 03:01 PM
