HELP!!!!! I AM STUMPED, Injectors wont work....NEED ADVICE
Old Jun 6, 2007 | 07:38 PM
EGhatch22's Avatar
Default HELP!!!!! I AM STUMPED, Injectors wont work....NEED ADVICE
I just swaped a h22 into a 94 integra. The car cranks put wont turn over. I checked for a spark and the car is getting a spark. When I checked the fuel. Thats when i saw a problem. The fuel travels to the fuel rail but the injectors for some reason wont give the motor any gas. I even checked my spark plug to smell any gas on it, didnt smell nothing. I was wondering if there is a fuse that controls the injectors? Do you think the injectors might be bad? I need some advice
Old Jun 7, 2007 | 07:04 AM
chicows18's Avatar
Default Re: HELP!!!!! I AM STUMPED, Injectors wont work....NEED ADVICE (EGhatch22)
The prelude motor has two types of injector systems. One of which utilizes a resistor box which is normally mounted near the brake booster. You would have to check which injectors you have since if you have the one with the resistor box and ur not using it wont work. Sounds like thats your problem.
Old Jun 7, 2007 | 01:20 PM
inspyral's Avatar
Measure the resistance across the injectors with a voltmeter. If they're lower than 10-12ohms, you need to run a resistor box.
Old Jun 7, 2007 | 03:14 PM
EGhatch22's Avatar
Default Re: (inspyral)
I got a muiltimeter and i measured the DC/AC Voltage in my first injector plug and it was 12.20. I wired a resistor box from the beginning of my swap. I still cant figure out why its not firing.
Old Jun 7, 2007 | 03:16 PM
EGhatch22's Avatar
Default Re: HELP!!!!! I AM STUMPED, Injectors wont work....NEED ADVICE (chicows18)
How do you check what injectors I have? I have a resistor box wired already.
Old Jun 7, 2007 | 03:21 PM
inspyral's Avatar
You don't measure voltage, you measure resistance, which is usually marked with a big ohm symbol. If you're getting 12.2 ohms across the injectors, then you don't need a resistor box, and the fact that you have one wired into the system may be your problem.
WAUKEENEM1
Dec 14, 2013 05:19 PM
Evansouders
Jul 30, 2013 05:50 PM
solsquad27
May 15, 2012 11:54 PM
Steeve_Civic
Dec 4, 2011 10:11 AM
thai-lorn
Apr 27, 2007 04:52 PM
